Kathryn
Firmware errors at 99%
On 10/5/2022 at 1:20 AM, izzy.lstbyzent@gmail.com said:
I'am getting the same error message once it hits 100%. I have tried unplugging the power cord before the 100% and plugging it back in but i get the same error message
Tell me your printer model please, I’ll send you the new instruction.
Good Morning this is regarding this post below ;
Hi,
I'm having the same issue with Epson WF-7710 on windows 10.
Thanks
https://inkchip.net/download/INKCHIP.net_Firmware_99_WF7710_v1.rar
I downloaded this same link above and the firmware is still stopping at 99%
In the video guide it shows that you don't need it to load 100%. When the load gets stuck at 75-85%, that's okay! You will need to pull the cable out at that point and put it back in.
Having problems with Epson 7710  updating firmware.  Gets to 99% and says fimware not updated.  Sent a message and have not gotten a reply.  This seems to be a common problem.  Has anyone gotten past this?  This is bad when you have work to do and cannot contact anyone.
On 2/14/2023 at 1:49 AM, greengoat said:
Hi,
Does this chipless software affect the maintenance tank levels or do these remain accurate?
Thank you for your reply
It affects only cartridges.
Chipless Firmware - software to the Epson’s printers.
The firmware makes to stop asking to reset the electronic ink level. This means client can print non-stop without zeroing breaks. No more hassle with changes of the cartridges and spending money on the services.
https://youtu.be/uB29zKLG7a0
I'm having the 99% error also, on a WF-7720, but then I clicked next or finish, and it showed 100%  I tried the activation software, and it didn't find the printer.  On the nozzle check, it reads eps@mail2v.com  10.43.FA2415.  Is that your firmware, or the Epson firmware?
In the video guide it shows that you don't have to load 100%. When the load gets stuck at 75-85%, that's okay! You will need to pull the cable out at that point and put it back in.
15 hours ago, Rick1974 said:
I have done everything the video says. I have done everything suggested in here. Still will not update.
XP 15000
Make sure you have stopped the installation process on 75-85% through the task manager.
On 4/13/2022 at 8:15 AM, Admin said:
Please try this new file :
https://inkchip.net/download/INKCHIP.net_Firmware_99_WF2860_v1.rar
1) Upload firmware which I sent.
2) Switch on in normal mode(!!!) just turn on button . - dont put printer in Program Update mode.
 (No need to press few buttons while turn on the printer)
The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF.
After that try to activate again.
Good Afternoon Admins! Apparently I need to update as my WF2860 is 'non downgraded' and I need to down load the above file. I have written Support and they have given me instructions. However this I do not understand???
'2) Start installing the firmware in the Firmware Mode (by pressing a certain button combinations)'
Im sorry, but where do I find the firmware Mode?
Generally I am able to figure this out, but Im operating on 2 strokes in the last 3 weeks...
Firmware Mode - special mode for updating printer firmware, which is activated when a certain buttons combination is pressed.
Please check button combination for your model.
Thank you Admin! I finally got the program to load. Now? It only prints in muted shadeS of blue. What have I done?
Here are some possible reasons why your printer prints blank forms after activating the firmware:
https://youtu.be/my58sHb9z5k
On 6/20/2023 at 8:39 PM, S Dempster said:
I'm have the same issue failing at 99% with me WF-2750
https://inkchip.net/download/INKCHIP.net_Firmware_99_WF2750_v1.rar
On 1/8/2022 at 10:44 AM, Howard said:
have the same problem with my XP-15000 with Epson firmware 20.41.NW99Z9
I have tried 6 times to install firmware with same results:
At 99% completion, I get the following pop-up message:
The Printer's firmware was not updated.
The firmware update did not complete. Try the following, then click [Retry].
- Ensure that the printer is connected (USB/Wi-Fi/Ethernet) to the computer.
- Ensure that the printer is powered on.
Click [Retry] to perform the update again
Click [next] to continue processing.
There are no error codes.
I am using windows 10
Current F/W ver NW2017
Black ink cartridge is empty, but display is at home screen.  Would this stop the update?
I have the same problem, and my black ink cartridge is empty also
Having the same problem with WF 7710 .  Tried using the task manger as mention above.   Lights never blinked.  Been at this for 3 hours.
In the video guide it shows that you don't need it to load 100%. When the load gets stuck at 75-85%, that's okay! !Stop the download process via the task manager before the error!
I AM HAVING THE SAME PROBLEM, SOFTWARE UPDATE LOADS TO 99% AND THEN GIVE AN ERROR MESSAGE SOFTWARE FAILED TO LOAD. i HAVE A WF-4734.
The loading process will get stuck at 75-85% - that is OK.
With the use of the task manager stop the loading process.
Printer will blink for about 5-15 minutes . It should then turn off automatically.
Now turn on the printer - Chipless Firmware should be installed!
 Run the Activation Software to insert your Activation Key.
Thanks!
Inkchip update keeps failing at 99% I've tried unplugging the power cord and back in with no luck. The printer always says the cartridges are installed incorrectly as they are chipless. Maybe this is the issue.
