izzy.lstbyzent@gmail.com 0 Posted October 4, 2022 I'am getting the same error message once it hits 100%. I have tried unplugging the power cord before the 100% and plugging it back in but i get the same error message Quote Share this post Link to post Share on other sites
Admin 17 Posted October 6, 2022 On 10/5/2022 at 1:20 AM, izzy.lstbyzent@gmail.com said: I'am getting the same error message once it hits 100%. I have tried unplugging the power cord before the 100% and plugging it back in but i get the same error message Hello, Tell me your printer model please, I’ll send you the new instruction. Quote Share this post Link to post Share on other sites
Devard Holder 0 Posted October 6, 2022 Good Morning this is regarding this post below ; Hi, I'm having the same issue with Epson WF-7710 on windows 10. Thanks https://inkchip.net/download/INKCHIP.net_Firmware_99_WF7710_v1.rar I downloaded this same link above and the firmware is still stopping at 99% Quote Share this post Link to post Share on other sites
Admin 17 Posted October 7, 2022 In the video guide it shows that you don't need it to load 100%. When the load gets stuck at 75-85%, that's okay! You will need to pull the cable out at that point and put it back in. Then turn the printer on just using the power button. Watch the video please: https://youtu.be/oF0DsDVPT7k Quote Share this post Link to post Share on other sites
nate 0 Posted October 28, 2022 im have the same issue with my xp-15000 Quote Share this post Link to post Share on other sites
Admin 17 Posted October 30, 2022 Are you following the instructions posted above? Quote Share this post Link to post Share on other sites
greengoat 0 Posted February 14, 2023 Having problems with Epson 7710 updating firmware. Gets to 99% and says fimware not updated. Sent a message and have not gotten a reply. This seems to be a common problem. Has anyone gotten past this? This is bad when you have work to do and cannot contact anyone. Quote Share this post Link to post Share on other sites
greengoat 0 Posted February 14, 2023 Hi, Does this chipless software affect the maintenance tank levels or do these remain accurate? Thank you for your reply Quote Share this post Link to post Share on other sites
Admin 17 Posted February 23, 2023 On 2/14/2023 at 1:49 AM, greengoat said: Hi, Does this chipless software affect the maintenance tank levels or do these remain accurate? Thank you for your reply Hello! It affects only cartridges. Chipless Firmware - software to the Epson’s printers. The firmware makes to stop asking to reset the electronic ink level. This means client can print non-stop without zeroing breaks. No more hassle with changes of the cartridges and spending money on the services. https://youtu.be/uB29zKLG7a0 Quote Share this post Link to post Share on other sites
burnsgolf 0 Posted February 27, 2023 I'm having the 99% error also, on a WF-7720, but then I clicked next or finish, and it showed 100% I tried the activation software, and it didn't find the printer. On the nozzle check, it reads eps@mail2v.com 10.43.FA2415. Is that your firmware, or the Epson firmware? Quote Share this post Link to post Share on other sites
Admin 17 Posted February 27, 2023 16 hours ago, burnsgolf said: I'm having the 99% error also, on a WF-7720, but then I clicked next or finish, and it showed 100% I tried the activation software, and it didn't find the printer. On the nozzle check, it reads eps@mail2v.com 10.43.FA2415. Is that your firmware, or the Epson firmware? In the video guide it shows that you don't have to load 100%. When the load gets stuck at 75-85%, that's okay! You will need to pull the cable out at that point and put it back in. Then turn the printer on just using the power button. Watch the video please: Quote Share this post Link to post Share on other sites
Rick1974 0 Posted March 18, 2023 I have done everything the video says. I have done everything suggested in here. Still will not update. XP 15000 Quote Share this post Link to post Share on other sites
Admin 17 Posted March 18, 2023 15 hours ago, Rick1974 said: I have done everything the video says. I have done everything suggested in here. Still will not update. XP 15000 Hello! Make sure you have stopped the installation process on 75-85% through the task manager. Quote Share this post Link to post Share on other sites
Diggie 0 Posted April 27, 2023 On 4/13/2022 at 8:15 AM, Admin said: Please try this new file : https://inkchip.net/download/INKCHIP.net_Firmware_99_WF2860_v1.rar 1) Upload firmware which I sent. 2) Switch on in normal mode(!!!) just turn on button . - dont put printer in Program Update mode. (No need to press few buttons while turn on the printer) The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer - chipless firmware is installed in your printer! After that try to activate again. Good Afternoon Admins! Apparently I need to update as my WF2860 is 'non downgraded' and I need to down load the above file. I have written Support and they have given me instructions. However this I do not understand??? '2) Start installing the firmware in the Firmware Mode (by pressing a certain button combinations)' Im sorry, but where do I find the firmware Mode? Generally I am able to figure this out, but Im operating on 2 strokes in the last 3 weeks... Quote Share this post Link to post Share on other sites
Admin 17 Posted April 30, 2023 On 4/28/2023 at 12:00 AM, Diggie said: Good Afternoon Admins! Apparently I need to update as my WF2860 is 'non downgraded' and I need to down load the above file. I have written Support and they have given me instructions. However this I do not understand??? '2) Start installing the firmware in the Firmware Mode (by pressing a certain button combinations)' Im sorry, but where do I find the firmware Mode? Generally I am able to figure this out, but Im operating on 2 strokes in the last 3 weeks... Firmware Mode - special mode for updating printer firmware, which is activated when a certain buttons combination is pressed. Please check button combination for your model. Quote Share this post Link to post Share on other sites
Diggie 0 Posted May 6, 2023 On 4/27/2023 at 3:00 PM, Diggie said: Good Afternoon Admins! Apparently I need to update as my WF2860 is 'non downgraded' and I need to down load the above file. I have written Support and they have given me instructions. However this I do not understand??? '2) Start installing the firmware in the Firmware Mode (by pressing a certain button combinations)' Im sorry, but where do I find the firmware Mode? Generally I am able to figure this out, but Im operating on 2 strokes in the last 3 weeks... Thank you Admin! I finally got the program to load. Now? It only prints in muted shadeS of blue. What have I done? Quote Share this post Link to post Share on other sites
Admin 17 Posted May 8, 2023 On 5/7/2023 at 1:10 AM, Diggie said: Thank you Admin! I finally got the program to load. Now? It only prints in muted shadeS of blue. What have I done? Hello! Here are some possible reasons why your printer prints blank forms after activating the firmware: https://youtu.be/my58sHb9z5k Quote Share this post Link to post Share on other sites
S Dempster 0 Posted June 20, 2023 I'm have the same issue failing at 99% with me WF-2750 Quote Share this post Link to post Share on other sites
Admin 17 Posted June 22, 2023 On 6/20/2023 at 8:39 PM, S Dempster said: I'm have the same issue failing at 99% with me WF-2750 Hello! Please try this new file : https://inkchip.net/download/INKCHIP.net_Firmware_99_WF2750_v1.rar 1) Upload firmware which I sent. 2) Switch on in normal mode(!!!) just turn on button . - dont put printer in Program Update mode. (No need to press few buttons while turn on the printer) The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer - chipless firmware is installed in your printer! After that try to activate again. Quote Share this post Link to post Share on other sites
martya 0 Posted July 1, 2023 On 1/8/2022 at 10:44 AM, Howard said: I have the same problem with my XP-15000 with Epson firmware 20.41.NW99Z9 I have tried 6 times to install firmware with same results: At 99% completion, I get the following pop-up message: The Printer's firmware was not updated. The firmware update did not complete. Try the following, then click [Retry]. - Ensure that the printer is connected (USB/Wi-Fi/Ethernet) to the computer. - Ensure that the printer is powered on. Click [Retry] to perform the update again Click [next] to continue processing. There are no error codes. I am using windows 10 Current F/W ver NW2017 Black ink cartridge is empty, but display is at home screen. Would this stop the update? I have the same problem, and my black ink cartridge is empty also Quote Share this post Link to post Share on other sites
Marilynw 0 Posted July 8, 2023 Having the same problem with WF 7710 . Tried using the task manger as mention above. Lights never blinked. Been at this for 3 hours. Quote Share this post Link to post Share on other sites
Admin 17 Posted July 9, 2023 16 hours ago, Marilynw said: Having the same problem with WF 7710 . Tried using the task manger as mention above. Lights never blinked. Been at this for 3 hours. Hello! In the video guide it shows that you don't need it to load 100%. When the load gets stuck at 75-85%, that's okay! !Stop the download process via the task manager before the error! You will need to pull the cable out at that point and put it back in. Then turn the printer on just using the power button. Watch the video please: Quote Share this post Link to post Share on other sites
RT625 0 Posted August 11, 2023 I AM HAVING THE SAME PROBLEM, SOFTWARE UPDATE LOADS TO 99% AND THEN GIVE AN ERROR MESSAGE SOFTWARE FAILED TO LOAD. i HAVE A WF-4734. Quote Share this post Link to post Share on other sites
Admin 17 Posted August 12, 2023 17 hours ago, RT625 said: I AM HAVING THE SAME PROBLEM, SOFTWARE UPDATE LOADS TO 99% AND THEN GIVE AN ERROR MESSAGE SOFTWARE FAILED TO LOAD. i HAVE A WF-4734. Hello! The loading process will get stuck at 75-85% - that is OK. With the use of the task manager stop the loading process. Printer will blink for about 5-15 minutes . It should then turn off automatically. Now turn on the printer - Chipless Firmware should be installed! Run the Activation Software to insert your Activation Key. Let me know the result! Thanks! Quote Share this post Link to post Share on other sites
Matt2023 0 Posted September 19, 2023 Inkchip update keeps failing at 99% I've tried unplugging the power cord and back in with no luck. The printer always says the cartridges are installed incorrectly as they are chipless. Maybe this is the issue. Quote Share this post Link to post Share on other sites
