Kathryn
Firmware errors at 99%
I have tried multiple times to install firmware with same results.
At 99% completion, I get the following pop-up message:
The Printer's firmware was not updated.
The firmware update did not complete. Try the following, then click [Retry].
- Ensure that the printer is connected (USB/Wi-Fi/Ethernet) to the computer.
- Ensure that the printer is powered on.
Click [Retry] to perform the update again
Click [next] to continue processing.
There are no error codes.
I am using Windows 7.
I can see the printer so it is clearly plugged in and turned on.
It is connected USB to the computer.
I have the same problem with my XP-15000 with Epson firmware 20.42.NW14L14
I have tried 6 times to install firmware with same results:
I am using windows 10
Hi I am have the same problem with an Epson xp-2100 firmware 02.30.MZ01JA. I tried the firmware many times but always get
https://inkchip.net/download/INKCHIP.net_Firmware_99_XP2100_v1.rar
  On 8/26/2021 at 6:31 PM, Christy said:
I am having the same issue with WF-2630.
You should install the firmware in normal mode.
8. Activate chipless firmware with the recovery key.
This is just an example of a process, it doesn't matter what model of printer you have. Please watch the video on our official YouTube channel: https://www.youtube.com/watch?v=h7qWYWjMNFQ
have the same problem with my XP-15000 with Epson firmware 20.41.NW99Z9
Current F/W ver NW2017
Black ink cartridge is empty, but display is at home screen.  Would this stop the update?
Hi, please watch the video guide from our official YouTube channel:
In the video guide it shows that you don't need it to load 100%. When the load gets stuck at 75-85%, that's okay! You will need to pull the cable out at that point and put it back in.
  On 1/17/2022 at 4:07 PM, rampoj said:
I have wf-2850 printer and the firmware update with the latest file goes all the way till 99% and then gives the message "firmware not updated". What should I do?
File used:
https://inkchip.net/download/INKCHIP.net_Firmware_99_WF2850_v1.rar
Tell us ,please,what mode did your install firmware in?Normal or updated?
io
Epson XP 15000 firmware 20.42.NW07k7
bloccato sul 99%
provo a disconecct powercord e ricollegare ma non completa al 100%
cosa dovrei fare?
THX
  On 1/23/2022 at 11:13 PM, Giacomo said:
io
bloccato sul 99%
cosa dovrei fare?
THX
You must install the firmware in normal mode.
To install the firmware in normal mode means to use only the power button.
Watch this video please:
After that try to activate again
Here’s the new firmware:
https://inkchip.net/download/INKCHIP.net_Firmware_99_XP15000_v1.rar
  On 8/10/2021 at 1:17 PM, Admin said:
I am using this firmware link and followed instructions.  it has stopped at 99%.  It says firmware update completed then it sits for about 5 minutes then I get the firmware could not be updated error screen
