Admin
INKCHIP - Chipless Solutions Firmware for Epson XP Series
Just now, Kat said:
I use compatible cartridges. Should I buy CISS also?
Definitely YES! It's completely another experience.
Can you advise any CISS model or manufacture?
If you will use it with Chipless firmware, you can buy any ciss for your XP-630.
You don't need CISS to be with CHIPS
You can buy any that suits you and compatible with your printer.
And as John said you can buy it without chips. It will be chipper than with them.
Thanks guys! I will check it on Amazon.
2 minutes ago, Koul said:
Hello, I have XP-434 and after it updates itself I can't instal your firmware. Please help!
Epson made a firmware update for this model, download our latest firmware for this model.
Just now, Koul said:
Printer was updated but firmware version wasn't changed. What to do?
It's an old printer model. You need to update it in NORMAL MODE. Don't put it in firmware update mode.
It's shows connection error when reached 14%.
I tried different USB ports and cables. Still the same.
Do you use CISS or cartridges for printing?
Try to put old cartridges with Chips inside. Printer needs chips to be installed before update.
It's helped. I put old 3d party cartridges and it updated well.
I knew I shouldn't throw them away😀
How can I restore my activation now?
You could use recovery code which was generated by activation software when you activate it before.
If you didn't save it, you need to buy new code.
I have it, thanks for helping!
On 11/26/2019 at 6:43 AM, Admin said:
If you have any question or meet problems with updating your Expression Home XP printer to Chipless Solution Firmware this topic is for you.
Ask your questions we will be glad to help you.
My Epson XP-446 printer does not have USB connection, is wireless. want to Know if still can download the firmware and activation hey
Hi, I have  Epson XP-4100 and I can`t find chipless firmware for this model.
Will you do chipless for it?
59 minutes ago, fernando del Aguila said:
how to connect my XP-446 to do the firmware  if My printer does not have USB port because is wireless
Hello Fernando, your printer have USB Port, our team was check specification for official web site.
Please check the link bellow https://epson.com/For-Home/Printers/Inkjet/Epson-Expression-Home-XP-446-Small-in-One-Printer/p/C11CF27202
Our Soft work only with USB Port.
i downloaded the frimware and the activation key but the firmware is a rar im using windows 10 i have no program to open it. how do i open it
I'm trying to download the chipless firmware on my computer for epson xp-4105 but every time I try to open the download it tells me could not find files needed to start. Help
Good Day!
To extract a file you need to use any archiver. For example, WinRAR or other...
I just purchased key for Epson XP-440.  I followed instructions exactly, it keeps failing and then it will start asking for paper and spitting out blank pages until the causes a paper jam and then I get an error code on the printer. Please tell me what im doing wrong, or why this is not working for me.
