Warwick
Does firmware update need to be switched off?
If I update a printer with your new firmware, can a connected user (in a small office shared printer setup) accidently overwrite the 'nochip' firmware by allowing the Epson standard printer drivers to do a 'update check' or is this facility disabled on the printer by your new firmware? I'd like to install updated printers in a couple of offices without relying on the staff to not mess things up with the new printers / firmware? I realise I can set the printer drivers to not check, but I cant keep every PC under my control. Thanks in advance.
After installing chipless firmware, be sure to turn off the automatic printer update in the settings!
Otherwise you will lose the firmware.
You mean settings in the Windows driver? My question clearly asks whether it is possible to prevent unskilled/ clueless users from needing to do this - ie with a setting on the printer. Is this possible?
You must turn off the automatic printer update in the settings on your computer to avoid unwanted firmware updates
This your question
Then Answer
And you say this
I hope your unskilled/ clueless workers  do indeed cost you money lots of money
