nikkigil 0 Posted July 25, 2020 Can someone assist me with the reading 1 error? I'm using WF-C5290, I even bought WIC thinking that the I need to but activation code. Kindly assist please. Thanks Quote Share this post Link to post Share on other sites
Admin 9 Posted July 26, 2020 Please try this new file for you. https://inkchip.net/download/INKCHIP.net_Firmware_99_WF5290_v1.rar 1) Upload firmware which I sent 2) Switch on in normal mode(!!!!) just turn on button . - dont put printer in Program Update mode. (no need to press few buttons while turn on the printer) The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer - chipless firmware is installed in your printer! Quote Share this post Link to post Share on other sites
nikkigil 0 Posted July 27, 2020 another issue when I downloaded your file. It says printer downgraded cannot be updated. Kindly assist further Quote Share this post Link to post Share on other sites
nikkigil 0 Posted July 28, 2020 Any update on this please? Quote Share this post Link to post Share on other sites
Admin 9 Posted July 29, 2020 Please try to upload the file in update mode and let me know the result Quote Share this post Link to post Share on other sites
nikkigil 0 Posted August 3, 2020 I uploaded the file in update mode, no issue, however, when I tried to run the activation code, the reading 1 error still appeared. I also tried to update just by uploading it and still the same error shows. Kindly please assist as I'm unable to use my printer since my intial ink has run out. the printer doesnt recognize the the cartridge tank Quote Share this post Link to post Share on other sites
nikkigil 0 Posted August 5, 2020 any update please? Quote Share this post Link to post Share on other sites
Admin 9 Posted August 7, 2020 Please tell me your order number and what country are you from? Quote Share this post Link to post Share on other sites
Kevin 0 Posted August 21, 2020 same problem as nikkigil Downgraded (It cannot be updated) Please update your firmware Quote Share this post Link to post Share on other sites
mylookhin 0 Posted January 29, 2021 same problem as @nikkigil Downgraded (It cannot be updated) Please update your firmware @Admin my order #17717 from thailand Quote Share this post Link to post Share on other sites
Admin 9 Posted February 4, 2021 On 8/21/2020 at 3:52 PM, Kevin said: same problem as nikkigil Downgraded (It cannot be updated) Please update your firmware Dear Kevin, Your problem was successfuly solved? Quote Share this post Link to post Share on other sites
Admin 9 Posted February 4, 2021 On 1/29/2021 at 2:18 PM, mylookhin said: same problem as @nikkigil Downgraded (It cannot be updated) Please update your firmware @Admin my order #17717 from thailand PLease write email with order # to our support: K.inkchip@gmail.com We will guide you how to solve it. Quote Share this post Link to post Share on other sites
JUAN MANUEL HERRERA 0 Posted February 18, 2021 Buenas tardes, tengo este mismo inconveniente... ayudenme por favor [Pedido #21280] (febrero 18, 2021) estoy en Colombia Quote Share this post Link to post Share on other sites
Admin 9 Posted February 19, 2021 Hi! What is your printer model? Quote Share this post Link to post Share on other sites
OKS 0 Posted May 15, 2021 i have same printer model with same problem. how to fix it? i already emailed support but no reply yet thanks Quote Share this post Link to post Share on other sites
Admin 9 Posted May 25, 2021 On 5/15/2021 at 2:45 PM, OKS said: i have same printer model with same problem. how to fix it? i already emailed support but no reply yet thanks Hi! What is your order number? Quote Share this post Link to post Share on other sites
Carlos 0 Posted June 6, 2021 To tambien tengo el mismo problema al activar, me sale ( failed error 1 ) intento instalar el firmware en modo normal y falla la actualizacion al 15%, prendo la impresora y no reconoce ni los cartuchos de tinta que tenia, nomas me dice que necesitan cambiarse y no me deja hacer nada la impresora, ni escanear. Mi orden es la 132047 para impresora xp-434 epson. Quote Share this post Link to post Share on other sites
karyaprinting 0 Posted July 25, 2021 Hi All, i have the same problem here... is it anybody had solved the problem? i already download the latest firmware, update through Program Update printer mode (Success), but to activate it shows Failed error 1, run the firmware in normal mode but stuck on Process Number 5 (Downgraded - it cannot be updated). Thank you All... Quote Share this post Link to post Share on other sites
Admin 9 Posted July 26, 2021 21 hours ago, karyaprinting said: Hi All, i have the same problem here... is it anybody had solved the problem? i already download the latest firmware, update through Program Update printer mode (Success), but to activate it shows Failed error 1, run the firmware in normal mode but stuck on Process Number 5 (Downgraded - it cannot be updated). Thank you All... Hi! What is your pinter model? Quote Share this post Link to post Share on other sites
yammy 0 Posted December 8, 2021 Quote Hi. I also have the same problem. Have you resolved this? Quote Share this post Link to post Share on other sites
Admin 9 Posted December 14, 2021 On 12/8/2021 at 1:54 PM, yammy said: Hi. I also have the same problem. Have you resolved this? Your original firmware cannot be downgraded to earlier versions, and our chipless firmware is an earlier version. Basic concepts of the solution: - Standard InkChip firmware. Chipless firmware, which must be loaded into the printer using Firmware Mode. - 99 InkChip firmware. Chipless firmware, which must be loaded into Normal Mode. - Firmware Mode - special mode for updating printer firmware, which is activated when a certain buttons combination is pressed. - Normal Mode - normal mode of operation of the printer, simple switching on the printer with the power button. Algorithm for solving the problem: 1. Check and memorize the firmware version of the printer. The firmware version displayed is the original non-update version. 2. Flash printer 99 with InkChip firmware in Firmware Mode. 3. When trying to activate the firmware with the Activation program and the activation code, the program will generate the Reading failed 1. 4. Start flashing the printer 99 again with InkChip firmware in Firmware Mode. When the firmware status in Firmware Mode reaches 100%, and the printer display finishes counting the percentage of the firmware status, you need to pull out the power cable of the printer. 5. Connect the power cable and turn on the printer. Recovery Mode will appear on the display. 6. Flash the printer with Inkchip firmware in Recovery Mode. 7. Check the firmware version of the printer. The firmware version displayed must be different from the non-renewable firmware version. This version is the chipless firmware version of InkChip. 8. Activate chipless firmware with the Activation program. https://inkchip.net/download/INKCHIP.net_Firmware_99_WF5290_v1.rar This is just an example of a process, it doesn't matter what model of printer you have. Please watch the video on our official YouTube channel: https://www.youtube.com/watch?v=h7qWYWjMNFQ And after that just ran again the inkchip firmware upload in normal mode. Quote Share this post Link to post Share on other sites
