Admin 17 Posted December 18, 2022 9 hours ago, John Ovid said: Hello. I have tried the above method, but still, it says reading failed. The moment I use the activation software. Also, the normal mode does not work. It gets stuck as early as 14% and says that it does not detect the printer (unless in UPDATE MODE). Is there any workaround regarding this problem? Hello! What is your printer model? Make sure you have turned off the printer's network connection to your computer and are only using a usb connection. Quote Share this post Link to post Share on other sites
John Ovid 0 Posted January 9, 2023 On 12/19/2022 at 1:03 AM, Admin said: Hello! What is your printer model? Make sure you have turned off the printer's network connection to your computer and are only using a usb connection. EPSON XP235A, and yes, only thru USB mode we're doing the firmware. And yet, we still encounter this problem all the time. Quote Share this post Link to post Share on other sites
Admin 17 Posted January 10, 2023 On 1/9/2023 at 5:02 AM, John Ovid said: EPSON XP235A, and yes, only thru USB mode we're doing the firmware. And yet, we still encounter this problem all the time. On 1/9/2023 at 5:02 AM, John Ovid said: EPSON XP235A, and yes, only thru USB mode we're doing the firmware. And yet, we still encounter this problem all the time. Try the same procedure on the another device. And make sure your connection is stable. Quote Share this post Link to post Share on other sites
John Ovid 0 Posted January 10, 2023 11 hours ago, Admin said: Hello, still the same problem occurs. By the way, I think I forgot to disclose this. In the initial work. months ago mighe be on September, it did work, for 3months, until an Epson Software/Firmware Update took place. Being the auto-updater automatically turned on, and a relative haphazardly confirming to proceed with the update. This I believe is the main reason as to why firmware for infinite ink was overwritten. However, what I don't understand is by even flashing the printer's firmware with the provided software, it encounters the problem mentioned above "readingh failed." I've also followed all directed techniques, to no avail. Quote Share this post Link to post Share on other sites
Admin 17 Posted January 11, 2023 You need to load the firmware without the chip and activate it with the recovery code, did you save it? You can repair chipless firmware with recovery code which was generated during flashing. Watch the instruction video from our official Youtube channel on how to restore chipless firmware with recovery code: https://youtu.be/K-aunKVMb-Y Quote Share this post Link to post Share on other sites
John Ovid 0 Posted January 16, 2023 (edited) On 1/11/2023 at 9:18 PM, Admin said: You need to load the firmware without the chip and activate it with the recovery code, did you save it? You can repair chipless firmware with recovery code which was generated during flashing. Watch the instruction video from our official Youtube channel on how to restore chipless firmware with recovery code: https://youtu.be/K-aunKVMb-Y Oh, so removing the ink cartridges first. But what if we forgot to save the recovery code. Is there a chance for it to work? Edit: I sent a request in WeChat for easier conversation. Thank you! Edited January 16, 2023 by John Ovid Quote Share this post Link to post Share on other sites
Admin 17 Posted January 17, 2023 On 1/16/2023 at 4:37 AM, John Ovid said: Oh, so removing the ink cartridges first. But what if we forgot to save the recovery code. Is there a chance for it to work? Edit: I sent a request in WeChat for easier conversation. Thank you! We can send it to you. please write us on support@inkchip.net Quote Share this post Link to post Share on other sites
firelion 0 Posted January 29, 2023 Bonjour, j'ai le meme soucis avec une xp235 Quote Share this post Link to post Share on other sites
Admin 17 Posted January 30, 2023 21 hours ago, firelion said: Bonjour, j'ai le meme soucis avec une xp235 Please try this updated file with the Chipless Firmware: https://inkchip.net/download/INKCHIP.net_Firmware_99_XP235_v1.rar 1) Upload the Chipless Firmware which is attached above. 2) Turn on the printer in the NORMAL MODE (using only the power button). Do not put the printer in the UPDATE MODE. The loading process will get stuck at 75-85% - that is OK. 3) With the use of the task manager stop the loading process. Printer will blink for about 5-15 minutes . It should then turn off automatically. 4) Now turn on the printer - Chipless Firmware should be installed! 5) Run the Activation Software to insert your Activation Key. Let me know the result! Thanks! Quote Share this post Link to post Share on other sites
SCarbruce 0 Posted February 8, 2023 I am having the same issue with my epson-xp 4105 please help. Quote Share this post Link to post Share on other sites
Admin 17 Posted February 11, 2023 On 2/8/2023 at 6:53 AM, SCarbruce said: I am having the same issue with my epson-xp 4105 please help. Hello! You should install the Chipless Firmware in NORMAL mode instead of UPDATE mode. Please read the instruction from our website carefully: https://inkchip.net/download/INKCHIP Instruction Method 14 (for 99 firmware).pdf Also, please watch the video guide from our official YouTube channel: https://youtu.be/oF0DsDVPT7k Let me know the result! Thank you! Quote Share this post Link to post Share on other sites
kaybae0922 0 Posted February 20, 2023 error as well when trying to activate. It defaults to a different language and closes out. XP-4100. Quote Share this post Link to post Share on other sites
Admin 17 Posted February 23, 2023 On 2/20/2023 at 1:07 AM, kaybae0922 said: error as well when trying to activate. It defaults to a different language and closes out. XP-4100. Please try to install program in normal mode . The instruction is sent above. Quote Share this post Link to post Share on other sites
Slty 0 Posted March 23, 2023 can you tell me how to go in the Firmware Mode - special mode for updating printer firmware, which is activated when a certain buttons combination is pressed For epson wf-c5790 Quote Share this post Link to post Share on other sites
caenegrao19@gmail.com 0 Posted April 27, 2023 Estou como o mesmo problema na xp-231 - "ler falhou - 1 Quote Share this post Link to post Share on other sites
Christian Aguas 1 Posted July 10, 2023 Hi! I have the same problem. My printer is WF 2850. Quote Share this post Link to post Share on other sites
Admin 17 Posted July 12, 2023 On 7/10/2023 at 6:56 PM, Christian Aguas said: Hi! I have the same problem. My printer is WF 2850. https://inkchip.net/download/INKCHIP.net_Firmware_99_WF2850_v1.rar 1) Upload firmware which I sent. 2) Switch on in normal mode(!!!) just turn on button . - dont put printer in Program Update mode. (No need to press few buttons while turn on the printer) The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer - chipless firmware is installed in your printer! Quote Share this post Link to post Share on other sites
RedCrimson 0 Posted August 15, 2023 Saludos, tengo el mismo problema que se menciona antes al momento de continuar el proceso de activación el programa muestra un mensaje "Read Failed -1" intente utilizando esta versión de firmware que compartió https://inkchip.net/download/INKCHIP.net_Firmware_99_XP430_v1.rar al momento de cargarlo con la impresora en modo normal, la actualización solo llega al 14% y muestra un mensaje donde dice que no puede continuar con la actualización Quote Share this post Link to post Share on other sites
Admin 17 Posted August 16, 2023 13 hours ago, RedCrimson said: Saludos, tengo el mismo problema que se menciona antes al momento de continuar el proceso de activación el programa muestra un mensaje "Read Failed -1" intente utilizando esta versión de firmware que compartió https://inkchip.net/download/INKCHIP.net_Firmware_99_XP430_v1.rar al momento de cargarlo con la impresora en modo normal, la actualización solo llega al 14% y muestra un mensaje donde dice que no puede continuar con la actualización ¡Hola! https://inkchip.net/download/INKCHIP.net_Firmware_XP430_v3.rar 1) Cargue el firmware sin chip que se adjunta arriba. 2) Encienda la impresora en el MODO NORMAL (usando solo el botón de encendido). No ponga la impresora en el MODO DE ACTUALIZACIÓN. El proceso de carga se atascará en un 75-85 %, eso está bien. 3) Con el uso del administrador de tareas, detenga el proceso de carga. La impresora parpadeará durante unos 5-15 minutos. Luego debería apagarse automáticamente. 4) Ahora encienda la impresora. ¡Se debe instalar el firmware sin chip! 5) Ejecute el software de activación para insertar su clave de activación. Quote Share this post Link to post Share on other sites
Cogite 0 Posted September 20, 2023 Hello, I have a problem to update my XP 15000. When it reaches 99% nothing happens during 5-10 minutes and a message saying that the firware is not installed finally appears. Printer is On and connected. I tried to unplugged the cordon when 99% is reached but the problem remains the same. Please, can you help me ? Quote Share this post Link to post Share on other sites
Admin 17 Posted September 21, 2023 On 9/20/2023 at 7:53 AM, Cogite said: Hello, I have a problem to update my XP 15000. When it reaches 99% nothing happens during 5-10 minutes and a message saying that the firware is not installed finally appears. Printer is On and connected. I tried to unplugged the cordon when 99% is reached but the problem remains the same. Please, can you help me ? Stop the boot process at 75-85% through the task manager. Don’t let it get 99% and error. Quote Share this post Link to post Share on other sites
theshak10 0 Posted October 17, 2023 Efectivo el procedimiento de instalar la V1 del firmware que el ADMINISTRADOR recomienda en esta página, todo el proceso me funcionó para epson XP 241, incluso esperé a que terminará de cargar y me dijo que no se podía cargar el firmware, pero la apagué y si lo tomó y ya la pude recuperar con la llave de recuperación, gracias. Quote Share this post Link to post Share on other sites
addy 0 Posted February 19, 2024 Hi! I uploaded the firmware from your website and it's working. Rading failed 1 appears on the screen and I can't activate the key. epson xp2200 Quote Share this post Link to post Share on other sites
didoche 0 Posted February 23, 2024 Hello, I uploaded the firmware from your website on my XP 2200 and it's working, got 100 % (same firmware) but when i want to activate online i have Raeding failed 1 appearing on the screen and I can't activate the key. do you have some kind of firmware update other then V1 ? Quote Share this post Link to post Share on other sites
Admin 17 Posted February 24, 2024 On 2/23/2024 at 5:19 PM, didoche said: Hello, I uploaded the firmware from your website on my XP 2200 and it's working, got 100 % (same firmware) but when i want to activate online i have Raeding failed 1 appearing on the screen and I can't activate the key. do you have some kind of firmware update other then V1 ? You should convince that installed the Chipless Firmware in NORMAL mode instead of UPDATE mode. Please read the instruction from our website carefully: https://inkchip.net/download/INKCHIP Instruction Method 14 (for 99 firmware).pdf Also, please watch the video guide from our official YouTube channel: https://youtu.be/oF0DsDVPT7k Quote Share this post Link to post Share on other sites
