Hi! I uploaded the firmware from your website and it's not working.  Rading failed 1 appears on the screen and I can't activate the key.
https://inkchip.net/download/INKCHIP.net_Firmware_99_XP240_v1.rar
https://inkchip.net/download/INKCHIP.net_Firmware_99_WF5790_v1.rar
Hola
Por favor, pruebe este nuevo archivo para usted.
https://inkchip.net/download/INKCHIP.net_Firmware_99_XP430_v1.rar
1) Subir el firmware que envié
2) Encienda en el modo normal (!!!!) sólo encienda el botón . - No pongas la impresora en el modo de actualización del programa. (No hay necesidad de presionar algunos botones mientras se enciende la impresora)
El proceso de carga se atascará en un 70-80% - ¡está bien!
Abrir el administrador de tareas y detener el proceso de actualización.
La impresora parpadeará durante unos 5-15 minutos y luego se apagará.
Ahora enciende la impresora. ¡El firmware sin chip está instalado en tu impresora!
Hello, your instructions is not that clear. I am having the same problem with my epson workforce c5790.
Open task manager and stop updater process. >> About this one, should i close the process even if the update is not finished yet? as long as it reached the 70-80% of the update, i need to close it?
And I also tried your instruction, but at 67% mark, the printer restarted itself. it didnt even reach the 70 to 80% of the update
1) Upload firmware from the website
  • Confused 1
Hola.
https://inkchip.net/download/INKCHIP.net_Firmware_99_XP15000_v1.rar
Hi,
I bought the WF-C5290 key and tried to follow the step you give ,
when activation online it showed reading failed - 1, I download the new firmware which you provide for other person who have same problem.
However, when I try to run the new firmware, it can not detect the printer unless I turn on the printer (with usual power bottom), when the printer is on it showed can not updated.
What should I do in this stage?
If you provide the new firmware link for me to download, when install the new firmware, should I turn on the printer or not?
Thank you.
On 3/5/2021 at 6:09 PM, Elvie said:
Hi,
Thank you.
Hi! Your original firmware cannot be downgraded to earlier versions, and our chipless firmware is an earlier version.
- Firmware Mode - special mode for updating printer firmware, which is activated when a certain buttons combination is pressed.
https://inkchip.net/download/INKCHIP.net_Firmware_99_WF5290_v1.rar
This is just an example of a process. It doesn't matter what model of printer you have. This video is in Russian, but you can turn on English subtitles : https://www.youtube.com/watch?v=Duyj-UHbzxE
