Rykker 0 Posted June 22, 2020 Hi! I uploaded the firmware from your website and it's not working. Rading failed 1 appears on the screen and I can't activate the key. Quote Share this post Link to post Share on other sites
Admin 17 Posted June 22, 2020 Please try this new file for you. https://inkchip.net/download/INKCHIP.net_Firmware_99_XP240_v1.rar 1) Upload firmware which I sent 2) Switch on in normal mode(!!!!) just turn on button . - dont put printer in Program Update mode. (no need to press few buttons while turn on the printer) The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer - chipless firmware is installed in your printer! Quote Share this post Link to post Share on other sites
Rykker 0 Posted June 22, 2020 I used the firmware for X-241. It was 100% ink. Thanks for the help. Quote Share this post Link to post Share on other sites
JustineMae 0 Posted June 27, 2020 PLEASE HELP ME ON MY WF 5790, WE HAVE THE SAME PROBLEM Quote Share this post Link to post Share on other sites
Admin 17 Posted June 29, 2020 Please try this new file for you. https://inkchip.net/download/INKCHIP.net_Firmware_99_WF5790_v1.rar 1) Upload firmware which I sent 2) Switch on in normal mode(!!!!) just turn on button . - dont put printer in Program Update mode. (no need to press few buttons while turn on the printer) The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer - chipless firmware is installed in your printer! Quote Share this post Link to post Share on other sites
Kevin 0 Posted August 21, 2020 I have the same problem in my C5290 Quote Share this post Link to post Share on other sites
Admin 17 Posted August 21, 2020 https://inkchip.net/download/INKCHIP.net_Firmware_99_WF5290_v1.rar Quote Share this post Link to post Share on other sites
henryhart 0 Posted August 27, 2020 hola, me sale error de lectura 1 en el modelo xp-431, ayuda por favor Quote Share this post Link to post Share on other sites
Admin 17 Posted August 27, 2020 Hola Por favor, pruebe este nuevo archivo para usted. https://inkchip.net/download/INKCHIP.net_Firmware_99_XP430_v1.rar 1) Subir el firmware que envié 2) Encienda en el modo normal (!!!!) sólo encienda el botón . - No pongas la impresora en el modo de actualización del programa. (No hay necesidad de presionar algunos botones mientras se enciende la impresora) El proceso de carga se atascará en un 70-80% - ¡está bien! Abrir el administrador de tareas y detener el proceso de actualización. La impresora parpadeará durante unos 5-15 minutos y luego se apagará. Ahora enciende la impresora. ¡El firmware sin chip está instalado en tu impresora! Quote Share this post Link to post Share on other sites
Paulene 0 Posted September 1, 2020 Hello! I'm having the same issue with the firmware for my Epson WF 7710/7720. Quote Share this post Link to post Share on other sites
Admin 17 Posted September 1, 2020 Hi! Please try this new file for you. https://inkchip.net/download/INKCHIP.net_Firmware_99_WF7710_v1.rar Quote Share this post Link to post Share on other sites
Jovelyn Sales 0 Posted September 24, 2020 On 6/30/2020 at 3:51 AM, Admin said: Please try this new file for you. https://inkchip.net/download/INKCHIP.net_Firmware_99_WF5790_v1.rar 1) Upload firmware which I sent 2) Switch on in normal mode(!!!!) just turn on button . - dont put printer in Program Update mode. (no need to press few buttons while turn on the printer) The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer - chipless firmware is installed in your printer! Hello, your instructions is not that clear. I am having the same problem with my epson workforce c5790. Open task manager and stop updater process. >> About this one, should i close the process even if the update is not finished yet? as long as it reached the 70-80% of the update, i need to close it? ---- And I also tried your instruction, but at 67% mark, the printer restarted itself. it didnt even reach the 70 to 80% of the update Quote Share this post Link to post Share on other sites
Admin 17 Posted September 24, 2020 What firmware version do you have now? Quote Share this post Link to post Share on other sites
jas 1 Posted October 7, 2020 received same message with xp15000 1 Quote Share this post Link to post Share on other sites
Admin 17 Posted October 12, 2020 1) Upload firmware from the website 2) Switch on in normal mode(!!!!) just turn on button . - dont put printer in Program Update mode. (no need to press few buttons while turn on the printer) 1 Quote Share this post Link to post Share on other sites
Alonso 0 Posted January 15, 2021 tengo el mismo problema con mi xp15000 Quote Share this post Link to post Share on other sites
Admin 17 Posted January 16, 2021 Hola. Por favor, pruebe este nuevo archivo para usted. https://inkchip.net/download/INKCHIP.net_Firmware_99_XP15000_v1.rar 1) Subir el firmware que envié 2) Encienda en el modo normal (!!!!) sólo encienda el botón . - No pongas la impresora en el modo de actualización del programa. (No hay necesidad de presionar algunos botones mientras se enciende la impresora) El proceso de carga se atascará en un 70-80% - ¡está bien! Abrir el administrador de tareas y detener el proceso de actualización. La impresora parpadeará durante unos 5-15 minutos y luego se apagará. Ahora enciende la impresora. ¡El firmware sin chip está instalado en tu impresora! Quote Share this post Link to post Share on other sites
mamabee 0 Posted February 24, 2021 I am having the same issue with my WF 2830 Quote Share this post Link to post Share on other sites
Admin 17 Posted February 25, 2021 Hi! Please try this new file for you. https://inkchip.net/download/INKCHIP.net_Firmware_99_WF2830_v1.rar Quote Share this post Link to post Share on other sites
Dis4DisplayName 0 Posted February 28, 2021 I am having the same issue with my XP-430. Any help is appreciated. Quote Share this post Link to post Share on other sites
Admin 17 Posted March 1, 2021 Hello! Please try this new file for you: https://inkchip.net/download/INKCHIP.net_Firmware_99_XP430_v1.rar Quote Share this post Link to post Share on other sites
pauly41gp@gmail.com 0 Posted March 4, 2021 (edited) I have the same problem with WF-C5210. Please help. Edited March 4, 2021 by pauly41gp@gmail.com Quote Share this post Link to post Share on other sites
Admin 17 Posted March 4, 2021 Hello! Please try this new file for you: https://inkchip.net/download/INKCHIP.net_Firmware_99_WF5210_v1.rar Quote Share this post Link to post Share on other sites
Elvie 0 Posted March 5, 2021 Hi, I bought the WF-C5290 key and tried to follow the step you give , when activation online it showed reading failed - 1, I download the new firmware which you provide for other person who have same problem. However, when I try to run the new firmware, it can not detect the printer unless I turn on the printer (with usual power bottom), when the printer is on it showed can not updated. What should I do in this stage? If you provide the new firmware link for me to download, when install the new firmware, should I turn on the printer or not? Thank you. Quote Share this post Link to post Share on other sites
Admin 17 Posted March 7, 2021 On 3/5/2021 at 6:09 PM, Elvie said: Hi, I bought the WF-C5290 key and tried to follow the step you give , when activation online it showed reading failed - 1, I download the new firmware which you provide for other person who have same problem. However, when I try to run the new firmware, it can not detect the printer unless I turn on the printer (with usual power bottom), when the printer is on it showed can not updated. What should I do in this stage? If you provide the new firmware link for me to download, when install the new firmware, should I turn on the printer or not? Thank you. Hi! Your original firmware cannot be downgraded to earlier versions, and our chipless firmware is an earlier version. Basic concepts of the solution: - Standard InkChip firmware. Chipless firmware, which must be loaded into the printer using Firmware Mode. - 99 InkChip firmware. Chipless firmware, which must be loaded into Normal Mode. - Firmware Mode - special mode for updating printer firmware, which is activated when a certain buttons combination is pressed. - Normal Mode - normal mode of operation of the printer, simple switching on the printer with the power button. Algorithm for solving the problem: 1. Check and memorize the firmware version of the printer. The firmware version displayed is the original non-update version. 2. Flash printer 99 with InkChip firmware in Firmware Mode. 3. When trying to activate the firmware with the Activation program and the activation code, the program will generate the Reading failed 1. 4. Start flashing the printer 99 again with InkChip firmware in Firmware Mode. When the firmware status in Firmware Mode reaches 100%, and the printer display finishes counting the percentage of the firmware status, you need to pull out the power cable of the printer. 5. Connect the power cable and turn on the printer. Recovery Mode will appear on the display. 6. Flash the printer with Inkchip firmware in Recovery Mode. 7. Check the firmware version of the printer. The firmware version displayed must be different from the non-renewable firmware version. This version is the chipless firmware version of InkChip. 8. Activate chipless firmware with the Activation program. https://inkchip.net/download/INKCHIP.net_Firmware_99_WF5290_v1.rar This is just an example of a process. It doesn't matter what model of printer you have. This video is in Russian, but you can turn on English subtitles : https://www.youtube.com/watch?v=Duyj-UHbzxE And after that just ran again the inkchip firmware upload in normal mode. Quote Share this post Link to post Share on other sites
