Jessica31284
WF2850 Won't fully update gets to 99% and then says update failed
I followed all the steps I get the firmware to 99% and then it says failed, My activation code is reading that it cant be rexcognized and I dont know what to do at this point
In the video guide it shows that you don't need it to load 100%. When the load gets stuck at 75-85%, that's okay! You will need to pull the cable out at that point and put it back in.
Then turn the printer on just using the power button.
Watch the video please:
I am having similar issues. I used the above video for reference. The installation gets to 99% before the error code pops up.
-the usb cable is not connected
- the wi-fi Ethernet connection to your printer was lost.
the printer is powered off.
i am using a usb cable. I do not have the printer(espon xp15000) connected to the wifi.
the print is on. But was idle so the screen did power down.
thank you in advance for any recommendations.
 https
