Wade O 0 Posted May 4 My attempt to install the firmware on the WF2860 keeps failing. Gets to 99% then says that it failed to install and problem could be the printer not connected or turned on. Quote Share this post Link to post Share on other sites
Admin 6 Posted May 7 On 5/4/2022 at 6:11 AM, Wade O said: My attempt to install the firmware on the WF2860 keeps failing. Gets to 99% then says that it failed to install and problem could be the printer not connected or turned on. Please try this new file : https://inkchip.net/download/INKCHIP.net_Firmware_99_WF2860_v1.rar 1) Upload firmware which I sent. 2) Switch on in normal mode(!!!) just turn on button . - dont put printer in Program Update mode. (No need to press few buttons while turn on the printer) The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer - chipless firmware is installed in your printer! After that try to activate again. Quote Share this post Link to post Share on other sites
