CKL
EPSON XP-430 FAILED
I purchased an activation key before starting the process. I followed the set up as directed but when I got to the Application Activation I got the Read Failed-1. I then downloaded the Application 99 for my printer model followed the directions but then it won't give me the Serial & ID code when I try to activate online. My printer now does not recognize my cartridges and it shuts off every time I click the activate online button.
What do I do?
What do I do?
https://inkchip.net/download/INKCHIP.net_Firmware_99_XP430_v1.rar
I have followed the instructions and it still does not work. It says my cartridges cannot be recognised. These are new Epson 288 ink cartridges I just put into the printer. I removed then replaced the cartridges and it still shows the warning message. I've done this many times already and the ink levels are depleting each time and I have yet to actually print anything with these new ink cartridges.
After installing the firmware you should activate it with the key. Did you manage to do this successfully?
I tried to activate the firmware but it still shows the Read Failed 1 error message. It won't allow me to activate online and after a few seconds the printer shuts down. Again I've tried this many times already.
Your original firmware cannot be downgraded to earlier versions, and our chipless firmware is an earlier version.  Basic concepts of the solution: - Standard InkChip firmware. Chipless firmware, which must be loaded into the printer using Firmware Mode. - 99 InkChip firmware. Chipless firmware, which must be loaded into Normal Mode. - Firmware Mode - special mode for updating printer firmware, which is activated when a certain buttons combination is pressed. - Normal Mode - normal mode of operation of the printer, simple switching on the printer with the power button.
This is just an example of a process, it doesn't matter what model of printer you have. Please watch the video on our official YouTube channel:
https://www.youtube.com/watch?v=h7qWYWjMNFQ
