Jeffboy
Firmware Update to 99% then says 'not updated'
After the Firmware Update process reached 99%, a message pops up "The printer's firmware was not updated". Regarding the troubleshooting listed, everything was followed, but after the 8th time, it is still the same
For the Epson WP-4730, i downloaded Firmware_99_WF4790_v1
On the Firmware Update Program, the version shows 30.74.CM99Z9
Please help
well after quite a few tries i just put my printer in recovery mode and the firmware installed with no problems. so i recommend you look up how to put the printer in recovery mode then do the firmware install
Edited by dragonrage173
- Firmware Mode - special mode for updating printer firmware, which is activated when a certain buttons combination is pressed.
8. Activate chipless firmware with the key.
This is just an example of a process, it doesn't matter what model of printer you have. Please watch the video on our official YouTube channel: https://www.youtube.com/watch?v=h7qWYWjMNFQ
1 hour ago, Rachel said:
I have tried 10 times and the firmware seems like its installing until the printer restarts.. then it says my ink cartridges are not in properly even if I take them out. Then says it couldn't be installed... about ready to give up.. what a waste of money
On 2/13/2022 at 4:10 PM, Brittany said:
I have xp-4105 it’s the only printer on my computer as the computer is brand new along with the printer. It will not show up on the activation list to put the code in.
