Brittany
Activation not showing my printer
I have xp-4105 it’s the only printer on my computer as the computer is brand new along with the printer. It will not show up on the activation list to put the code in.
This might be because there are too many printers on devices and printers. That’s what might help you: close the Activator Software, turn off your printer, go to PC and remove all printers that may be in "Devices and Printers", then turn your printer on and it will install again, then open the launcher software again and it might appear normally.
Which step in the process are you referring to? Where you type in the activation code?
