Vincent Decasa 0 Posted November 16, 2021 Hello, I started the chipless conversion process today and I keep getting the error at 99% during the firmware update. I have the Epson WF 7710 and the current firmware version is FA24I5 24/05/2018. I've also attached an image of the error message. Please help. Quote Share this post Link to post Share on other sites
Admin 17 Posted November 18, 2021 Hi! Tell me please which mode have you been trying to install firmware in? Quote Share this post Link to post Share on other sites
Vincent Decasa 0 Posted November 18, 2021 I tried both normal mode and firmware update mode. Someone from your company already helped me. Everything is fine now. It seems to be working, well at least for the time being. Anyway thanks for the reply. I might contact you again soon if something goes wrong. Thank you. Quote Share this post Link to post Share on other sites
aply 0 Posted February 5, 2022 (edited) Hi I am experiencing this same issue. Any help would be greatly appreciated. I have an EPSON WF-3730 printer. The firmware file name is INKCHIP.net_Firmware_WF3720.exe Edited February 5, 2022 by aply Quote Share this post Link to post Share on other sites
Jacob Findly 0 Posted February 5, 2022 I am having the same issue with my WF 2760, the firmware failed at 99 percent, I tried several times. Quote Share this post Link to post Share on other sites
tamccain 0 Posted January 10, 2023 I am having this same issue with failure at 99%, this is for a WF-3730 Quote Share this post Link to post Share on other sites
Admin 17 Posted January 12, 2023 Hello! Do you using only USB connection to the printer? You should disable network connection. Quote Share this post Link to post Share on other sites
Dragonfly Heart 0 Posted January 31, 2023 On 1/12/2023 at 4:13 PM, Admin said: Hello! Do you using only USB connection to the printer? You should disable network connection. I'm also hanging up at 99% . Are you saying that since I've connected by USB to printer, I should disconnect internet connection for my computer? Quote Share this post Link to post Share on other sites
Admin 17 Posted February 1, 2023 On 1/31/2023 at 11:05 PM, Dragonfly Heart said: I'm also hanging up at 99% . Are you saying that since I've connected by USB to printer, I should disconnect internet connection for my computer? Yes, please try only with the use of USB cable. Quote Share this post Link to post Share on other sites
