Jerry_H
WARRANTY AND RESTORE SOFTWARE
Yes, You can restore back to the original software!
So there won't  be any problem with this)
Thank you !
Hola, si quiero cambiar al firmware original, como lo haría y donde consigo el firmware original?
Lo tienes en tu página para descargar el firmware original?
¡Hola!
Puedes conectar tu impresora a Internet y actualizarla, o puedes descargarla de Internet.
  On 9/22/2021 at 5:49 PM, juarez molina victor anton said:
 compre hace dos días para epson xp 241 y me da error. quiero la devolución del dinero juarez molina victor antonio
¡Buenas tardes!
Envíe una captura de pantalla del error para que podamos ayudarle.
If I restore back to the original software or upgrade the firmware with the printer utility, it is possible then to performe a chipless firmware recovery back again?
I have an Epson WF-2830
Thanks
mt
Thanks
mt
You can restore chipless firmware on your printer with the Recovery Code, but only once.
  On 3/5/2023 at 11:42 PM, brandiemize1991@icloud.com said:
I never received a recovery code?? I need to restore my printer but I can't find it. Can someone walk me through this restoration process, please!? I'm lost!
It will be generated during key activation.
tra
How can I get a recovery code? I purchased back in 10/2021 and cant find my emailwith the code
  On 4/10/2023 at 5:31 PM, travelindesigns said:
where do i find the recovery code/
The recovery code is generated during key activation and is used to recover chipless firmware.
