bee 0 Posted August 6, 2021 Hi can i know if the activation is supporting epson wf2861 ( singapore set ) thanks. Quote Share this post Link to post Share on other sites
bee 0 Posted August 6, 2021 i got this msg and stuck at 99%. my printer model is 2861, does 2860 and 2861 use the same firmware installer? thanks. Quote Share this post Link to post Share on other sites
bee 0 Posted August 9, 2021 hi admin, any updates? thanks, Quote Share this post Link to post Share on other sites
Admin 17 Posted August 10, 2021 Hi! Yes, if works for your model. have you been trying to install the firmware in the normal mode? Quote Share this post Link to post Share on other sites
Ricky Fai 0 Posted August 4, 2023 (edited) After clicked the "INKCHIP.net_Activation.exe", got error message window- just a code, not understand. After click OK, program window closed and nothing happen. What should be done? Edited August 4, 2023 by Ricky Fai Quote Share this post Link to post Share on other sites
Admin 17 Posted August 4, 2023 Please try this new activator: https://inkchip.net/download/activation.rar Quote Share this post Link to post Share on other sites
Ricky Fai 0 Posted August 6, 2023 Same. After close and re click the exe file again, can show English language, and click "activate online", error message " Wrong ID code". Also your whatsapp no. cannot be used Quote Share this post Link to post Share on other sites
Admin 17 Posted August 6, 2023 4 hours ago, Ricky Fai said: Same. After close and re click the exe file again, can show English language, and click "activate online", error message " Wrong ID code". Also your whatsapp no. cannot be used Could you please make a short videо where we can see how you install the firmware and send it to us at: support@inkchip.net. Thank you! Quote Share this post Link to post Share on other sites
Ricky Fai 0 Posted August 8, 2023 Hi, Firmware upload to printer is no problem (shown 100% done and success), but go to activation got problem. Need to re-do the firmware uploading again? Video for activation problem sent to you already Quote Share this post Link to post Share on other sites
Admin 17 Posted August 8, 2023 10 hours ago, Ricky Fai said: Hi, Firmware upload to printer is no problem (shown 100% done and success), but go to activation got problem. Need to re-do the firmware uploading again? Video for activation problem sent to you already The load should not get to 100% when installing in normal mode. Most likely you are doing something wrong. Quote Share this post Link to post Share on other sites
Ricky Fai 0 Posted August 9, 2023 According to the download instruction, it shall be 100%. If not, what should be the correct procedure? Quote Share this post Link to post Share on other sites
Admin 17 Posted August 11, 2023 In the video guide it shows that you don't need it to load 100%. When the load gets stuck at 75-85%, that's okay! You will need to pull the cable out at that point and put it back in. Then turn the printer on just using the power button. Watch the video please: Quote Share this post Link to post Share on other sites
Ricky Fai 0 Posted August 12, 2023 Hi, both the video and manual said " if loading stop before reach 100%"; But my case was that it did not stop (only holding for a few seconds at certain time). Is it meaning that I have to unplug the power cord at certain % of loading? I have sent you the screw video of uploading firmware. Pls check Quote Share this post Link to post Share on other sites
Admin 17 Posted August 12, 2023 6 hours ago, Ricky Fai said: Hi, both the video and manual said " if loading stop before reach 100%"; But my case was that it did not stop (only holding for a few seconds at certain time). Is it meaning that I have to unplug the power cord at certain % of loading? I have sent you the screw video of uploading firmware. Pls check Hello! About this issue, we have already replied to you on email. Thank you! Quote Share this post Link to post Share on other sites
Ricky Fai 0 Posted August 13, 2023 Replied, awaiting your further instruction Quote Share this post Link to post Share on other sites
Ricky Fai 0 Posted August 15, 2023 Any update? Quote Share this post Link to post Share on other sites
Admin 17 Posted August 16, 2023 On 8/15/2023 at 4:27 AM, Ricky Fai said: Any update? Let it stop the download process through the task manager and proceed to activation. 1 Quote Share this post Link to post Share on other sites
Ricky Fai 0 Posted August 19, 2023 Finally successfully do the activation, and can do normal printing already. Thanks for Admin guiding patiently... Quote Share this post Link to post Share on other sites
Admin 17 Posted August 19, 2023 Glad to hear it! Thank you! Quote Share this post Link to post Share on other sites
