Admin
INKCHIP - Chipless Solutions Firmware for Epson EP Series
If you have any question or meet problems with updating your EP series printer to Chipless Solution Firmware this topic is for you.
Ask your questions we will be glad to help you.
I bought  CISS to Epson EP-807A and updated it to Chipless Firmware at home, but now printing is bad quality.
Is it because of your firmware? Can it damage the printer?
Hello Alf7, thank you for contacting us.
Our chipless firmware is based on the Epson one, and cannot damage you printer.
The problem may be in CISS or Inks you use.
You can try to print on OEM cartridges for you printer to check if the problem with ink or printer.
  On 12/3/2019 at 11:56 AM, Takedo18 said:
I updated my EP-807. But I ask for cartridges. What should I do? HELP!
Hello! Did you buy the activation code?
You need now to download activation software and use activation code in it.
You can check manual on the site for more information.
  On 12/4/2019 at 9:43 AM, Daniel said:
Hi! Activation program can't identify my EP-709. What can I do?
Hello Daniel,
Does firmware update pass well?
Try to use another USB port and update firmware one more time.
  On 12/4/2019 at 9:45 AM, Admin said:
Hello Daniel,
Thanks for your help!
I did as you said and it's worked!
Can I use old USB port now?
  On 12/4/2019 at 9:54 AM, harry said:
Hello, I made an oder for 10 codes for EP-808 but didn't receive an invoice. Help!
Hello Harry!
Please check the SPAM folder in your mail.
If there is no email with the invoice, leave ticket to our support on this site.
You can freely use any USB port. You also can connect printer to other PC without any problem.
  On 12/4/2019 at 9:59 AM, Admin said:
Hello Harry!
You were right! Mail get to the spam folder. I already paid and get my codes!
Hello Derek, unfortunately we don't have firmware for this printer.
All supported models you can find on our site and we always adding new models.
Do you have in plans to make a firmware for it?
How often do you add new firmwares?
No we don't have plans for adding this models.
There is no schedule in adding new firmwares, as it depends on each model and epson updates.
But we trying to add chipless firmwares for all new models as soon as possible.
i use epson printer c869r
i try to use chipless firmware, but the video tutorial in this link not work for me.
ca Admin give the update tutorial ?
the 4th step is now work!
I bought firmware and activation code, order 176907.  When installing according to the YouTube video instructions, the firmware starts to update but then it has stopped at 45%. It has been over an hour and it is still at 45%. HELP
We now have updated instructions on the website. Please check it out: https://inkchip.net/download/INKCHIP Instruction Method 14 (for 99 firmware).pdf
