Greenwall 0 Posted May 16, 2021 Hello Installed firmware and activated printed 1 page last night today it just keeps giving me error codes 031002 Order number was 110197 Quote Share this post Link to post Share on other sites
Admin 17 Posted May 24, 2021 Hi! Please send me the screenshot of the error. Quote Share this post Link to post Share on other sites
christle 0 Posted August 27, 2021 I have been trying to get my Epson XP-15000 to download the firmware. It keeps going to 99% and says it did not download. Quote Share this post Link to post Share on other sites
christle 0 Posted August 27, 2021 I have been trying to get my Epson XP-15000 to download the firmware. It keeps going to 99% and says it did not download. I have tried everything i see on here with no result Quote Share this post Link to post Share on other sites
Admin 17 Posted August 28, 2021 14 hours ago, christle said: I have been trying to get my Epson XP-15000 to download the firmware. It keeps going to 99% and says it did not download. I have tried everything i see on here with no result Hi! You shoul install the firmware from the website in normal mode. Quote Share this post Link to post Share on other sites
magtaf 0 Posted August 30, 2021 On 8/28/2021 at 8:07 AM, Admin said: Hi! You shoul install the firmware from the website in normal mode. I am also having this issue with software version 20.41.NW99Z9. What do you mean by normal mode? Quote Share this post Link to post Share on other sites
magtaf 0 Posted August 30, 2021 I don’t know how to do update or normal mode. Lease send me instructions on both. Quote Share this post Link to post Share on other sites
Admin 17 Posted September 9, 2021 hi! This is the normal mode instruction, you should try it Quote Share this post Link to post Share on other sites
Samnicole 0 Posted September 14, 2021 Is there any update on this issue? I am having the same error code 031002, also stops at 99%. I have watched the youtube video and it has not helped to answer my question. Quote Share this post Link to post Share on other sites
thisispaul 0 Posted September 14, 2021 Same, Ive done all suggested above. Hopefully this didn't turn mine into a brick. I guess I need a refund. Quote Share this post Link to post Share on other sites
Admin 17 Posted September 24, 2021 On 9/14/2021 at 5:24 AM, Samnicole said: Is there any update on this issue? I am having the same error code 031002, also stops at 99%. I have watched the youtube video and it has not helped to answer my question. With the printer powered on, remove the power cord from the back. Wait 2 minutes. Plug back in the power cord and power it on. Do you still have the error? Quote Share this post Link to post Share on other sites
MarcyMiranda 0 Posted September 24, 2021 Hello, I just tried this and it did not work. I have an EPSON WF2850. Quote Share this post Link to post Share on other sites
cadirae@hotmail.com 0 Posted September 29, 2021 I cannot get the ink to install, and cannot try to complete the firmware download because it is still in set up mode. Quote Share this post Link to post Share on other sites
Admin 17 Posted October 6, 2021 On 9/29/2021 at 3:39 AM, cadirae@hotmail.com said: I cannot get the ink to install, and cannot try to complete the firmware download because it is still in set up mode. Hi! Could you please send the screenshot? Quote Share this post Link to post Share on other sites
Admin 17 Posted October 6, 2021 On 9/24/2021 at 9:29 PM, MarcyMiranda said: Hello, I just tried this and it did not work. I have an EPSON WF2850. Hi! Have you tried to reinstall the firmware? Quote Share this post Link to post Share on other sites
J_Causey 0 Posted December 2, 2022 Same error as everyone above. Cannot download firmware will not get past 99%. Been trying for hours. Watched all videos, read every forums and directions on website. Nothing. Quote Share this post Link to post Share on other sites
Admin 17 Posted December 3, 2022 Hello! Did you stop the boot process at 75-85 percent through the task manager? You can't let the boot process get to 99 or 100 percent and fail. If you did everything correctly, then went to the activation program and inserted the key, and you failed to activate the chipless firmware, then I will send you instructions on how to flash the printer in recovery mode. Just let me know! Thanks! Quote Share this post Link to post Share on other sites
brus0990@gmail.com 0 Posted November 11, 2023 Hello. My XP 15000 is apparently in recovery mode - the start button blinks, but the firmware does not see the printer. what can be done to flash it? Quote Share this post Link to post Share on other sites
