J0ke
wf-4720 wrong id code
I've used https://inkchip.net/download/INKCHIP.net_Firmware_WF4720_v1.rar and tried https://inkchip.net/download/INKCHIP.net_Firmware_99_WF4790_v1.rar
neither have worked for my 4720.
99 firmware should be run in normal mode, not in update mode.
Did you follow the installation instructions in normal mode?
I tried the 99 in normal mode, the transfer makes it to 75% then the printer reboots and the update fails.
- Firmware Mode - special mode for updating printer firmware, which is activated when a certain key combination is pressed.
This is just an example of a process. It doesn't matter what model of printer you have. This video is in Russian, but you can turn on English subtitles : https://www.youtube.com/watch?v=Duyj-UHbzxE
