I am from Kenya. Purchased code. I have tried about a dozen times to update the firmware on my Epson 15000. The process begins each time, and then I get the message that the printer could not be updated. I am given prompts of things to try. I have tried all of them, and always get the same message. I have tried with just the network connection, just a USB connection, and with both, all with the same failure.
I would appreciate your help figuring out how to update the firmware on the printer. And if it is not possible, how can I get a refund?
- Firmware Mode - special mode for updating printer firmware, which is activated when a certain key combination is pressed.
This is just an example of a process. It doesn't matter what model of printer you have. This video is in Russian, but you can turn on English subtitles : https://www.youtube.com/watch?v=Duyj-UHbzxE
https://inkchip.net/download/INKCHIP.net_Firmware_99_XP15000_v1.rar
