Firmware update went without issue. Firmware is at CM27KB.
When I run the activation program (version 1.0.0.1) which has a bunch of interface issues, and I click Generate a error appears: Wrong ID code.
I have the printer connected via USB, I have run the program as an administrator as well as a regular user.
What do need to do to activate?
https://inkchip.net/download/INKCHIP.net_Firmware_99_WF4790_v1.rar
So, I have uploaded the attached firmware to the printer without issue. The printer shows the firmware version as 30.74.CM27J5. After restarting the printer, I still have a cartridge error.  Maintenance Error - Cannot recognize Ink Cartridge.  Try installing again.
Suggestions?
Currently, I have color ink that this a non-Epson ink, the other inks are Epson 802XL.
hi. how did you get it to enter the firmware mode? i have the same firmware CM27KB and i can not make it load the firmware mode. i press the corner and the power button and does not show. could you please help me with this. im trying to load it first before i even buy this software key for my printer Epson WF 4730. Thanks
