tengo problemas con la activación. dice que el sistema no puede leer al momento de darle al botón activar online. WF-C5290.
Numero de Pedido: 178080
15 hours ago, Danmor said:
What mode did you install the firmware in? In normal mode or in update mode?
Order 187065
Hello, I bought a key from you to make the WF3720 chipless, when activated and rebooted, the device still requires cartridges. What should I do ?
1 minute ago, Nikolay said:
Order 187065
 10091 means that application could not connect to the server. Please, check if you have the access: 1. Enable telnet client in the windows components. 2. In the command line type telnet 211.159.168.205 20102. If you get empty screen with input prompt it means that server is available system wide and something is blocking license.exe specifically. If you get any error this means that either this IP/port blocked locally for the entire system or on the router/provider side or server is currently not available.
On 9/2/2021 at 1:18 AM, shannon.huston said:
hello i have the wf 3733 and it wont accept the firmware
Hi! Please send me the screenshot of the error so we can help you.
I am having the same problem as post number 1. I was able to download the firmware and the activation ran but it did not populate a serial number... instead a new activation box popped up and I input my code but it could not be recognized.
I just purchased the activation code and did the firmware setup.  When doing set 2 it says it doesn't reconize the act. code.
jbuy
