The firmware updated with no issues when I go to activation and click activate online I get error Wrong ID Code...
Order# 12242
Good afternoon! Send a screenshot with an error so that we can help you.
I have the a WF-3720, brand new, never put original ink into machine. It has not gone passed the setup screen. That being said. I updated successfully but I am getting "wrong id code" error
Here is my Order #11517
wrong id code error message when click on online activation, emailed for support two days ago no answer. on this thread no solution is posted
what is the point of paying for a key if you will never get a chance to activate it?
I am having the same issue as the people above. My firmware was installed perfectly but when I put my activation code in, it says wrong ID code. I have an epson WF-3730
Edited by Katewing322
To add photo
Please try this new file for you:
https://inkchip.net/download/INKCHIP.net_Firmware_99_WF3720_v1.rar
2) Switch on in normal mode(!!!) just turn on button . - dont put printer in Program Update mode. (no need to press few buttons while turn on the printer)
Now power on the printer - chipless firmware is installed in your printer!)))
Hello I am having the same exact issue I have a wf 2860. I am also getting the wrong id code message everything else when through perfectly fine but i am now stuck on this part please help.
https://inkchip.net/download/INKCHIP.net_Firmware_99_WF2860_v1.rar
2) Switch on in normal mode(!!!) just turn on button . - dont put printer in Program Update mode. (No need to press few buttons while turn on the printer)
On 3/5/2021 at 8:51 PM, Julian Sereno said:
Buenas tardes he comprado el código y cuando lo meto me dice que la clave introducida no es correcta
¡Buenas tardes! Envíe una captura de pantalla del error para que podamos ayudarle.
On 10/16/2020 at 5:24 PM, donboricuaq@gmail.com said:
 Hi, Hello I am having the same exact issue I have a wf 4720. I am also getting the wrong id code message everything else when through perfectly fine but i am now stuck on this part please help.
 I am having the same issue with WF-4720.. could you please help.. Thank You.
https://inkchip.net/download/INKCHIP.net_Firmware_99_WF4790_v1.rar
