Jim 0 Posted September 13, 2020 The firmware updated with no issues when I go to activation and click activate online I get error Wrong ID Code... Order# 12242 Quote Share this post Link to post Share on other sites
Admin 6 Posted September 13, 2020 Good afternoon! Send a screenshot with an error so that we can help you. Quote Share this post Link to post Share on other sites
brandon000 0 Posted September 19, 2020 I have the a WF-3720, brand new, never put original ink into machine. It has not gone passed the setup screen. That being said. I updated successfully but I am getting "wrong id code" error Quote Share this post Link to post Share on other sites
brandon000 0 Posted September 19, 2020 20 minutes ago, brandon000 said: I have the a WF-3720, brand new, never put original ink into machine. It has not gone passed the setup screen. That being said. I updated successfully but I am getting "wrong id code" error Here is my Order #11517 Quote Share this post Link to post Share on other sites
brandon000 0 Posted September 19, 2020 11 minutes ago, brandon000 said: Here is my Order #11517 Quote Share this post Link to post Share on other sites
Admin 6 Posted September 19, 2020 Please try this new file for you. https://inkchip.net/download/INKCHIP.net_Firmware_99_WF3720_v1.rar 1) Upload firmware which I sent 2) Switch on in normal mode(!!!!) just turn on button . - dont put printer in Program Update mode. (no need to press few buttons while turn on the printer) The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer - chipless firmware is installed in your printer! Quote Share this post Link to post Share on other sites
donboricuaq@gmail.com 0 Posted October 16, 2020 Hi, I am having the same issue with WF-4720.. could you please help.. Thank You. Quote Share this post Link to post Share on other sites
UlissesOrtiz71 0 Posted October 20, 2020 wrong id code error message when click on online activation, emailed for support two days ago no answer. on this thread no solution is posted what is the point of paying for a key if you will never get a chance to activate it? Quote Share this post Link to post Share on other sites
UlissesOrtiz71 0 Posted October 20, 2020 inkchip.net_activation has error message wrong id code Quote Share this post Link to post Share on other sites
Admin 6 Posted October 21, 2020 Good afternoon! Send a screenshot with an error so that we can help you. Quote Share this post Link to post Share on other sites
M. Yates 0 Posted November 3, 2020 (edited) I am having this exact same issue with WF-7710 Edited November 3, 2020 by M. Yates Quote Share this post Link to post Share on other sites
Admin 6 Posted November 3, 2020 Please try this new file for you. https://inkchip.net/download/INKCHIP.net_Firmware_99_WF7710_v1.rar 1) Upload firmware which I sent 2) Switch on in normal mode(!!!!) just turn on button . - dont put printer in Program Update mode. (no need to press few buttons while turn on the printer) The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer - chipless firmware is installed in your printer! Quote Share this post Link to post Share on other sites
caliekbk 0 Posted November 28, 2020 Hello I am having the same issue with my wf 3733. Please help Quote Share this post Link to post Share on other sites
Franklin Omar Angulo Yela 0 Posted December 4, 2020 Hello, please help me with an error that I get when activating the serial in an Epson WorkForce Pro WF 3730, it gives me when activating online, "Wrong ID code". Nuevo pedido: #14788 Quote Share this post Link to post Share on other sites
Katewing322 0 Posted February 28, 2021 (edited) I am having the same issue as the people above. My firmware was installed perfectly but when I put my activation code in, it says wrong ID code. I have an epson WF-3730 Edited February 28, 2021 by Katewing322 To add photo Quote Share this post Link to post Share on other sites
Admin 6 Posted March 1, 2021 Hello! Please try this new file for you: https://inkchip.net/download/INKCHIP.net_Firmware_99_WF3720_v1.rar 1) Upload firmware which I sent 2) Switch on in normal mode(!!!) just turn on button . - dont put printer in Program Update mode. (no need to press few buttons while turn on the printer) The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer - chipless firmware is installed in your printer!))) Quote Share this post Link to post Share on other sites
Akiya 0 Posted March 5, 2021 Hello I am having the same exact issue I have a wf 2860. I am also getting the wrong id code message everything else when through perfectly fine but i am now stuck on this part please help. Quote Share this post Link to post Share on other sites
Julian Sereno 0 Posted March 5, 2021 Buenas tardes he comprado el código y cuando lo meto me dice que la clave introducida no es correcta Quote Share this post Link to post Share on other sites
Admin 6 Posted March 7, 2021 On 3/5/2021 at 5:23 AM, Akiya said: Hello I am having the same exact issue I have a wf 2860. I am also getting the wrong id code message everything else when through perfectly fine but i am now stuck on this part please help. Hello! Please try this new file for you: https://inkchip.net/download/INKCHIP.net_Firmware_99_WF2860_v1.rar 1) Upload firmware which I sent 2) Switch on in normal mode(!!!) just turn on button . - dont put printer in Program Update mode. (No need to press few buttons while turn on the printer) The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer - chipless firmware is installed in your printer! Quote Share this post Link to post Share on other sites
Admin 6 Posted March 7, 2021 On 3/5/2021 at 8:51 PM, Julian Sereno said: Buenas tardes he comprado el código y cuando lo meto me dice que la clave introducida no es correcta ¡Buenas tardes! Envíe una captura de pantalla del error para que podamos ayudarle. Quote Share this post Link to post Share on other sites
deansigwalt@yahoo.com 0 Posted March 28, 2021 On 10/16/2020 at 5:24 PM, donboricuaq@gmail.com said: Hi, Hello I am having the same exact issue I have a wf 4720. I am also getting the wrong id code message everything else when through perfectly fine but i am now stuck on this part please help. I am having the same issue with WF-4720.. could you please help.. Thank You. Quote Share this post Link to post Share on other sites
Admin 6 Posted March 29, 2021 23 hours ago, deansigwalt@yahoo.com said: Hello! Please try this new file for you: https://inkchip.net/download/INKCHIP.net_Firmware_99_WF4790_v1.rar 1) Upload firmware which I sent 2) Switch on in normal mode(!!!) just turn on button . - dont put printer in Program Update mode. (No need to press few buttons while turn on the printer) The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer - chipless firmware is installed in your printer! Quote Share this post Link to post Share on other sites
mincha 0 Posted August 21, 2021 i need help with this WF-2630 Quote Share this post Link to post Share on other sites
Admin 6 Posted August 26, 2021 Hi! which mode have you installed firmware in? Quote Share this post Link to post Share on other sites
Juan Carlos 0 Posted December 15, 2021 (edited) hola también tengo problemas con una wf-2630 me genera el mismo error. Edited December 15, 2021 by Juan Carlos Quote Share this post Link to post Share on other sites
