my printer is an L6190 epson, i see the printer on deep clean, but not on waste ink counter
This model is compatible with the waste ink counter reset utility.
You can watch a video on our official YouTube channel to see how easy it is to use:
https://youtu.be/VSgxJvVKV_k
You can download the waste ink counter reset utility in one of five languages at
https://inkchip.net/wic/
You can purchase a reset key at the following link:
https://inkchip.net/price/
Choose the number of WIC keys and place the order.
my printer does not show on the application. is there any extra configuration on the app or printer that i must make?
Please state the model of your printer.
And if you have already placed an order, please write down the order number.
Thank you.
5 hours ago, Tshepo said:
hi, could there be a reason?
Did you install the Microsoft Visual C++ x64 and x86 2017-2022 packages? Make sure that packages are installed.
Please send confirmation ( screenshot from the downloading menu that packages are installed) on the support@inkchip.net.
10 hours ago, RichPG said:
No encuentro el modelo de mi. Impresora XP 2205, me puede orientar?, Gracias
Desgraciadamente, no tenemos ninguna solución para este modelo de impresora.
Posted (edited)
my printer is an ESPSON XP 4100, i see the printer on deep clean, but not on waste ink counter.
Please let me know if there is a solution. Thank you !
Edited by Alone
I have an ET-4500 (Epson) which informed me that a printer component was at the end of it's service life. (Waste Ink Container). On August 6, 2023,  I purchased the WIC software            (Order # 540987) reset from you, but the software doesn't recognize the printer ('no printer found'). The printer is connected directly to my desktop. What should I do?
Make sure you used a usb cable ( check usb port) when installing the firmware and have a stable internet,are you?
