EMUzing
Downgraded(it cannot be updated)
launching inkchip firmware  it finds printer then dont let me checkmark the box it says Downgraded(it cannot be updated)  currently running 10.58.LQ29M3
You should install 99 firmware in Recovery Mode.
What is the best way to get into recovery mode as I've tried via holding the power and the right corner of the display till it says update mode but that's not the correct way..
On 4/12/2023 at 6:52 PM, EMUzing said:
Tryed holding power and top right corner takes me to a update rom prompt
- Standard InkChip firmware.
Chipless firmware, which must be loaded into the printer using Firmware Mode.
- 99 InkChip firmware.
Chipless firmware, which must be loaded into Normal Mode.
- Firmware Mode - special mode for updating printer firmware, which is activated when a certain buttons combination is pressed.
4. Start flashing the printer 99 again with InkChip firmware in Firmware Mode. When the firmware status in Firmware Mode reaches 100%, and the printer display finishes counting the percentage of the firmware status, you need to pull out the power cable of the printer. 5. Connect the power cable and turn on the printer. Recovery Mode will appear on the display.
8. Activate chipless firmware with the activator
This is just an example of a process, it doesn't matter what model of printer you have. Please watch the video on our official YouTube channel: https://www.youtube.com/watch?v=h7qWYWjMNFQ
