hi there i have a problem with the instalation of the firmware
i try to install and everything is ok but in 99 % make a error
the printer is on and tue usb is conected
in the first image say the version is confirmed
in 99 % say this error an all is ok. printer on and conected usb.. when pulse in retry .. the bar stop in 28 % and send to print infinte page in blank
the only way to stop is disconnect usb and next
so... i try to install with the V3 version and V2.
somebody can help me? thanks
In the video guide it shows that you don't need it to load 100%. When the load gets stuck at 75-85%, that's okay! You will need to pull the cable out at that point and put it back in.
