pcenforme
epson xp-452 bourrage papier fermez le module scanner
in first thanks for your soft save another printer epson
hello I disassembled the epson xp452 because it tells me paper jam then close the scanner module I see no paper would you have any idea? thanks in advance
bonjour j'ai demonte la epson xp452 car elle m'indique bourrage papier puis fermez le module du scanner je vois aucun papier auriez vous une idée? merci d'avance
Please  text us on support@inkchip.net as to this issue and provide with screenshots of the error.
