I purchased a product key to reset waste ink counter, after following the instructions and installing the software prior to the use of the product key it gave me a product key is invalid error.
I have install the Microsoft C ++ packages before running the utility
This is  screenshot from the download menu, so that I can see the date and time when the packages were installed.
I also removed the spurious characters from the key.
Thank you for your reply.
Please send me a screenshot of the error and screenshot from the download menu so I can check, if packages were installed correctly.
19 hours ago, avi said:
I am facing the same problem, softwear show me that key is already usesd.Please help.
Did you install the Microsoft C ++ packages before running the utility?
If yes, please send me a screenshot from the download menu, so that I can see the date and time when the packages were installed.
Hola enfrento el mismo problema, después de instalar la aplicación de Microsoft e instalar el WIC no funciona y sigue em mismo error E-11. El tampón de la impresora necesita repararse contacte con EPSON. Imagen
Es necesario instalar ambos paquetes de Microsoft Visual C++ x64 y x86.
¿Qué tipo de error está recibiendo?
