elneciogomez
"File is Not Found" Al actualizar Firmware
Hola. Al tratar de actualizar una impresora Epson XP 440 con el Firmware descargado de esta pagina para luego comprar la clave me da este error "FILE IS NOT FOUND".
Como puedo solucionarlo?
Gracias.
Good afternoon!
Your problem means that the firmware was not installed correctly.
Try to install unique firmware for your model:
https://inkchip.net/download/INKCHIP.net_Firmware_99_XP440_v1.rar
And follow these instructions:
2) Switch on in normal mode(!!!!) just turn on button. Don't put printer in Program Update mode. No need to press few buttons while turn on the printer!
Now power on the printer - chipless firmware is installed in your printer.
  On 9/26/2021 at 4:37 PM, bluezman66 said:
trying to download firmware but will not open when finished with download, any help with this for a wf 7720.
Thanks
Have you turned the antivirus off?
