TonerStore 0 Posted June 18, 2020 (edited) Compré la llave para activar el chipless en una WF2830, pero al ir al programa de activación, me dice que el modelo no es compatible o Unsupported printer model. Ya le instalé el firmware, y aún así me aparece ese error. Es la única impresora que tengo instalada y en el programa me aparece seleccionada en la parte de arriba. Repito, una Epson WF2830. Edited June 18, 2020 by TonerStore Quote Share this post Link to post Share on other sites
TonerStore 0 Posted June 18, 2020 In english. I bought the key to activate the chipless on an WF2830, but when I use the program to activate it, it says Unsupported Printer Model. I already installed the firwmare and the error is still there. Is the only printer I have installed and the program correctly selects it at the top. Again, is an Epson WF2830. Quote Share this post Link to post Share on other sites
Admin 17 Posted June 19, 2020 Hola! Por favor, haga una captura de pantalla con un error. Lo comprobaremos. Quote Share this post Link to post Share on other sites
TonerStore 0 Posted June 19, 2020 Este es el problema. Quote Share this post Link to post Share on other sites
Guillo231 0 Posted July 2, 2020 I have the same problem with my Epson WF-2830. Please help Quote Share this post Link to post Share on other sites
Admin 17 Posted July 2, 2020 Good afternoon! Tomorrow we will send you a new file from July 1 with an updated version. Quote Share this post Link to post Share on other sites
Admin 17 Posted July 3, 2020 Please try this new file for you. https://inkchip.net/download/INKCHIP.net_Firmware_99_WF2830_v1.rar 1) Upload firmware which I sent 2) Switch on in normal mode(!!!!) just turn on button . - dont put printer in Program Update mode. (no need to press few buttons while turn on the printer) The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer - chipless firmware is installed in your printer! Quote Share this post Link to post Share on other sites
Silvio 0 Posted July 16, 2020 I have the same problem with my Epson WF-7210. Please help New firmware from Inkchip web site is correct install - all is OK Quote Share this post Link to post Share on other sites
Admin 17 Posted August 11, 2020 The problem should not be in the firmware, please remove all files and install the firmware from our site for your model, and try an updated activation program. activation.exeFetching info... Quote Share this post Link to post Share on other sites
destructor67810@gmail.com 0 Posted March 20, 2022 XP - 2150 problem ??? Quote Share this post Link to post Share on other sites
Admin 17 Posted March 22, 2022 On 3/20/2022 at 5:50 PM, destructor67810@gmail.com said: XP - 2150 problem ??? Hi! Please, use this activation program: https://inkchip.net/download/INKCHIP.net_Activation.exe Quote Share this post Link to post Share on other sites
destructor67810@gmail.com 0 Posted March 29, 2022 (edited) Next problem........ My email for buying activation code is : staub.pierre@wanadoo.fr Edited March 29, 2022 by destructor67810@gmail.com Quote Share this post Link to post Share on other sites
destructor67810@gmail.com 0 Posted March 29, 2022 (edited) Edited March 29, 2022 by destructor67810@gmail.com Quote Share this post Link to post Share on other sites
Admin 17 Posted March 30, 2022 On 3/29/2022 at 6:57 PM, destructor67810@gmail.com said: Next problem........ My email for buying activation code is : staub.pierre@wanadoo.fr Hi! You are inserting the key in the wrong place. You need to click the "activate online" button and insert the key in the pop-up window. Also, make sure, that you have entered the key correctly: without spaces before and after. Quote Share this post Link to post Share on other sites
destructor67810@gmail.com 0 Posted March 30, 2022 Thx a lot !!! Everything works fine Quote Share this post Link to post Share on other sites
nymphamontez@gmail.com 0 Posted March 30, 2022 I am interested in purchasing the items needed to make my WF-2830 chip less, what all is needed and will it work? Thanks in advance, Ninfa Montez Quote Share this post Link to post Share on other sites
florent 0 Posted June 22, 2022 Bonjour, voila le message d'erreur que j'ai quand je tente de rentrer la clé, de l'aide s'il vous plait. Quote Share this post Link to post Share on other sites
Admin 17 Posted June 29, 2022 Hello! Make sure that you have installed firmware and activator for correct model of printer. Quote Share this post Link to post Share on other sites
