  On 5/30/2022 at 5:27 PM, Duchesse said:
I am going through the same thing...just tried installing and it get to 99% and then fails...
Please try this new file :
https://inkchip.net/download/INKCHIP.net_Firmware_UP_XP15000_v1.rar
1) Upload firmware which I sent.
2) Switch on in normal mode(!!!) just turn on button . - dont put printer in Program Update mode.
 (No need to press few buttons while turn on the printer)
The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF.
After that try to activate again.
  On 6/8/2022 at 3:32 AM, Ozkar said:
I already did everything you mention and it doesn't happen 99%
- Firmware Mode - special mode for updating printer firmware, which is activated when a certain buttons combination is pressed.
4. Start flashing the printer 99 again with InkChip firmware in Firmware Mode. When the firmware status in Firmware Mode reaches 100%, and the printer display finishes counting the percentage of the firmware status, you need to pull out the power cable of the printer. 5. Connect the power cable and turn on the printer. Recovery Mode will appear on the display.
8. Activate chipless firmware with the Activation program
This is just an example of a process, it doesn't matter what model of printer you have. Please watch the video on our official YouTube channel:
https://www.youtube.com/watch?v=h7qWYWjMNFQ
