Kerry
Epson WF2840 Firmware stalls at 71%
I bought the Inkchip firmware for Epson WF2830 I have tried to install it for the last 2 days.
It stalls ar around 71%
I think it might be because I have updated Epson firmware which stops the Inkchip firmware from installing
I have changed cables, restarted, reinstalled printer, you name it I have given it a go, Closed anti virus, searched the internet for ideas.
I am really frustrated is there anyone out there that might have a solution
I should have said I have an Epson WF2830.
I notice on my printer it says "A newfirmware is released; Update the firmware from setup menu.
But I have stopped any new firmware in my setup
In which mode did you install the firmware? In normal mode or update mode?
Please send me a screenshot of the error so I can help you.
  On 7/20/2022 at 11:47 AM, Julius0007 said:
My WF2830 as well. The printer will restart at 71%.. The original firmware of my printer is AL05K3.
In the video guide it shows that you don't need it to load 100%. When the load gets stuck at 70-80%, that's okay! You will need to pull the cable out at that point and put it back in.
Then turn the printer on just using the power button.
Watch the video please:
I’m still having an issue. I’m doing it via Wi-Fi network connection. Is the USB cord the only way?
Yes, of course. Disable your network connection to the computer. Use ISB cable only.
