Hello...
I have a Epson XP 211. My S.O. is Win10 pro x64.
i'm update the firmware, and restart the printer.
The printer start ok, but the red led of ink out is on.
I activate the serial, and restart the printer.
Then, all the leds blink, and the printer not work.
How can i fix?
Thanks!
The printer (Epson XP-211 does not have a screen.
When I turn it on, it does the normal power-up process, and when the head is parked, all the leds start blinking, and it doesn't respond.
This is a video of the reaction of printer...
http://www.sdigitales.com.ar/VID_20220318_090933.mp4
All the leds blinks after turn on...
Before install the serial, the printer turn on ok, and only on the ink out led.
The error most likely occurs because the maintenance box of your printer has reached the end of its life.
You can download  the WIC reset utility and perform the ink level reading function:
https://inkchip.net/wic/
Here is the video from our official YouTube channel to see how easy to use our WIC reset utility for Epson printers:
https://youtu.be/VSgxJvVKV_k
