Jen Mamita 0 Posted December 16, 2021 Please help in the activation, it says failed with error code. Quote Share this post Link to post Share on other sites
Jen Mamita 0 Posted December 16, 2021 Communication Failed 10092 Quote Share this post Link to post Share on other sites
Jen Mamita 0 Posted December 16, 2021 also the firmware failed. Quote Share this post Link to post Share on other sites
TerryC 0 Posted December 17, 2021 (edited) I have the same issue. Edited December 17, 2021 by TerryC included screen shot Quote Share this post Link to post Share on other sites
Admin 16 Posted December 17, 2021 12 hours ago, TerryC said: I have the same issue. To install the firmware in normal mode means to use only the power button. Not the power button and the display corner. You don't have to put the printer into update mode. In the videos we sent you that you don't need it to load 100%. When the load gets stuck at 75-85%, that's okay! You will need to pull the cable out at that point and put it back in. Then turn the printer on just using the power button. Watch the video again: https://youtu.be/oF0DsDVPT7k Let me know the result! Thank you! Quote Share this post Link to post Share on other sites
TerryC 0 Posted December 17, 2021 Still no different. Only done in normal mode as you can see, it doesn't stop at 75-85% it goes all the way to 99% then the message that it failed comes up. Quote Share this post Link to post Share on other sites
Leonardo Santa Clara 0 Posted December 21, 2021 I need a quick help from you my client's printer activation failed to activate code 10092. I saw that it refers to the previously used key... I received the email and immediately tried to activate the printer. I need an urgent solution... I've sent a message via whatsapp with all the details of the purchase and also through the form on your page... Quote Share this post Link to post Share on other sites
Leonardo Santa Clara 0 Posted December 21, 2021 Just now, Leonardo Santa Clara said: Preciso de uma ajuda rápida de você. A ativação da impressora do meu cliente falhou ao ativar o código 10092. Vi que se refere à chave usada anteriormente ... Recebi o e-mail e tentei imediatamente ativar a impressora. Preciso de uma solução urgente ... Enviei uma mensagem via whatsapp com todos os detalhes da compra e também através do formulário da sua página ... o meu modelo é EPSON WF 579R Quote Share this post Link to post Share on other sites
TerryC 0 Posted December 22, 2021 Communication Failed 10092 Quote Share this post Link to post Share on other sites
Admin 16 Posted December 23, 2021 14 hours ago, TerryC said: Communication Failed 10092 Hello! This error number means that the key has already been used. What is your model? Please, make screenshot with error 10092, we will check. Quote Share this post Link to post Share on other sites
BradK 0 Posted January 1, 2022 I copied the activation code from my email, pasted it into the 'Activation Code' section and clicked 'Activate' I get the message 'Activation code can not be recognize' My printer is an Epson WF-3733, Firmware download into printer went fine but I can't activate it? Quote Share this post Link to post Share on other sites
BradK 0 Posted January 1, 2022 When I first clicked 'Activate Online' it said 'Wrong ID code' After that I put the ID code from my email into the 'Activation Code' section and clicked 'Activate' Then I get the message 'Activation code can not be recognize' Quote Share this post Link to post Share on other sites
BradK 0 Posted January 1, 2022 I got it to work. I bought the printer brand new and never did the initial setup. I installed the cartridges the printer came with as that was part of the setup, after that it worked. THANKS FOR SAVING ME $$$ and eliminating Epson's terrible business practices! Quote Share this post Link to post Share on other sites
Mew43 0 Posted January 9, 2022 im getting this message when i try to use the code they sent me in the email to activate my wf-7720, can someone tell me why? Quote Share this post Link to post Share on other sites
Admin 16 Posted January 16, 2022 On 1/10/2022 at 1:58 AM, Mew43 said: im getting this message when i try to use the code they sent me in the email to activate my wf-7720, can someone tell me why? Hi! The error occurs if you insert the key incompletely, incorrectly, or leaving extra spaces in front and behind the activation key. Quote Share this post Link to post Share on other sites
