Order 309811
For an Epson ET-2650
I tried several time with the key you sent but it doesn't works : Provided key is invalid
I already used your service for another printer, same model, so I know its not the comupter (Windows 10 64bits)
Thanks before for your help.
Did you install the Microsoft C ++ packages before running the utility?
Also, the error might be because you erased some key characters or left extra spaces in front and behind the key.
On 1/16/2022 at 11:44 PM, BABA CARDIA said:
Salut !
Non je rien à installer  il est bien arrivé jusqu'à 99% et puis le message apparaît  message erreur .
What solution did you buy?If it is WIC utility,you have to install Microsoft packages which were in the instruction.
2 hours ago, rhazi nadia said:
Bonjour,
Je viens d'acheter une clé mais j'ai un message clé invalide pourtant j'ai fait copier coller. que dois-je faire ?
Tell us ,please,have you installed Microsoft C++ packages as it was written in the instruction?
Please,send confirmation (screenshot) that both 2 (64x and 86x packages) are installed. Thank you!
