Admin
INKCHIP - Chipless Solutions Firmware for Epson SC-P Series
Activation error please help. Epson p800
firmware updated with inkchip
and turn off and turn on then use the activation file come up with these andbI put my key code everywhere doesn’t work.
Program doesn’t look on video and doesn’t work for me.
please let me know whAt to dofor my printer.
Edited by Taehan
You need to remove the extra spaces on the front and back of the key when you put it in the field.
Hello everyone. I’m in desperate need of a chipless solution for my Epson P800. I have no problem spending the money but I can’t seem to find a firmware download on this website. Can anyone point me in the right direction or share said file? This is a US model.
Thank you so very much 🙏🙏🙏
Erixk Brown
On 11/26/2019 at 5:48 AM, Admin said:
If you have any question or meet problems with updating your SureColor SC-P printer to Chipless Solution Firmware this topic is for you.
Ask your questions we will be glad to help you.
What is the latest firmware supposed to be. I installed this and it’s not working for me. I have the epson p600
On 12/4/2019 at 6:06 AM, Admin said:
It's correct firmware version.
You can use recovery code to reinstall the firmware.
Mine is AT10J. How do I get the right firmware. I already bought the firmware but it not giving me the right one
Have have done the firmware for epson p600. Since then it tells me my ink cartridges are empty or doesn’t recognize cartridge. It won’t print anything. it says the firmware is AT10J7 is that the right firmware for epson p600 and what else do I need to do to it this going. I have done everything the directions say to do
The latest version is loaded on the site. Make sure you followed the procedure correctly and installed firmware successfully.
