Kumara
EPSON WF-C5890 just blink not finish update firmware
7 hours ago, Kumara said:
After wait more than 15minute , printer stil not turn off automatically
In the video guide it shows that you don't need it to load 100%. When the load gets stuck at 75-90%, that's okay! You will need to pull the cable out at that point and put it back in.
Then turn the printer on just using the power button.
Watch the video please:
On 12/17/2024 at 5:29 AM, Kumara said:
please help....
Make sure you used a usb cable when installing the firmware and have a stable internet, are you?
Go to the menu devices and printers and check if the computer sees the connection to the printer.
On 12/26/2024 at 4:10 AM, Kumara said:
That firmware cannot update.....how to update?
The original firmware of your printer cannot be downgraded to earlier version. Please, follow the instructions below.
The firmware, which you need to use:
https://inkchip.net/download/INKCHIP.net_Firmware_99_WF5890_v1.rar
1) Check and memorize current firmware version of your printer.
2) Start installing the firmware in the Firmware Mode (by pressing a certain button combinations)
3) When the firmware installation reaches 100%  you need to disconnect the power cable from your printer.
Wait for about 10 seconds and then plug the cable in. A message will appear on your printer screen, saying that the printer is in Recovery Mode.
4) Start installing the Inkchip firmware again, wait for the firmware to load, your printer will shut down. Turn your printer on.
5) Check your printer's firmware version. It must be different. This means that the process was successful.
6) Now you need to use the Activation Program from our website and activate it with the key.
After the activation you have to reboot your printer.
The chipless firmware is installed on your printer!
Please watch the instruction video from our YouTube channel for a clear explanation:
https://www.youtube.com/watch?v=h7qWYWjMNFQ
This is just an example of the process, it does not matter which model of printer you have.
