stevencalaes 0 Posted December 7, 2024 Hola tengo un problema con el modelo workforce-5290 pro me da el error 032051 error de la impresora Vuelva a encender la impresora Consulte el manual p/obtener detalles si alguien supiera como resolver el problema Quote Share this post Link to post Share on other sites
Admin 17 Posted December 10, 2024 On 12/7/2024 at 8:34 PM, stevencalaes said: Hola tengo un problema con el modelo workforce-5290 pro me da el error 032051 error de la impresora Vuelva a encender la impresora Consulte el manual p/obtener detalles si alguien supiera como resolver el problema The Epson error code 032051 typically indicates an issue with the printhead or ink system. Here's a step-by-step guide to resolve it: Restart the Printer: Turn off, unplug for 5 minutes, then restart. Check Ink Cartridges: Ensure they are seated properly and not empty. Replace if needed. Clean Printhead: Use the printer’s maintenance menu to perform a cleaning. Quote Share this post Link to post Share on other sites
