19 minutes ago, user7777 said:
Hi,
Could you please help since i cannot activate online?
it's showing error "Read Failed -1"
Thank you
Hello! Start the Chipless firmware installation in Normal Mode (pressing the power button). Don’t put the printer in Update Mode with key combination.
Hello, I bought a key for C5390 and I cannot update the firmware used with chipless. Its stuck with the factory firmware, the printer resets after using the inkchip firmware, and shows READ FAILED-1 when trying to activate with the key. I used the InkChip firmware in normal mode, no firmware update mode.
Hola compre la licencia para el equipo wf c5390 y no encuentro el instalador. Podrían subirlo por favor?
You should convince that installed the Chipless Firmware in NORMAL mode instead of UPDATE mode.
Please read the instruction from our website carefully:
Also, please watch the video guide from our official YouTube channel:
What difficulties exactly do you have? Please, describe it and send a screenshot.
