Puppy 0 Posted September 10, 2020 Dear Admin, My order no. 12056. No issue to issue the firmware. Activation code key activate online. Received Activation code write failed 3 See attached for details. Pls advise me to solve this problem. Seem like cannot write to my WF-c5790 machine. Quote Share this post Link to post Share on other sites
Admin 17 Posted September 10, 2020 Solution: Step 1 Download and extract Zip archive with WF-C5790 Firmware: https://inkchip.net/download/INKCHIP.net_Firmware_99_WF5790_v1.rar Step 2 Delete all USB printers installed on your PC except that You want to make chipless. Reboot PC, restart printer. Step 3 Connect printer to PC (with Windows OS) by proper USB cable. Disable all Epson processes and services. Step 4 Upload Firmware to printer in the NORMAL MODE (do NOT use service mode yet just start the printer with the power button). Step 5 When Firmware Update process is complete - printer will restart - usually it will take only a few minutes but can continue for 10-20 minutes in some rare cases. If process hangs - replug power cable and start printer manually. Step 6 Now check current firmware version. If NO - restart the printer and try once more time. Step 7 Extract all files from License.zip archive to local folder on Your PC. Run activation.exe utility and click on Activate Online button and input Your Activation Key. Quote Share this post Link to post Share on other sites
Puppy 0 Posted September 12, 2020 Hi Admin, Problem solved. My problem was that I fixed 3rd ink & installed the activation code. After fixed the original ink back to the machine and run with activation code. Then received installation successful. Then off the printer & fixed 3rd party ink and ON the machine. Thank you. On 9/11/2020 at 2:21 AM, Admin said: Solution: Step 1 Download and extract Zip archive with WF-C5790 Firmware: https://inkchip.net/download/INKCHIP.net_Firmware_99_WF5790_v1.rar Step 2 Delete all USB printers installed on your PC except that You want to make chipless. Reboot PC, restart printer. Step 3 Connect printer to PC (with Windows OS) by proper USB cable. Disable all Epson processes and services. Step 4 Upload Firmware to printer in the NORMAL MODE (do NOT use service mode yet just start the printer with the power button). Step 5 When Firmware Update process is complete - printer will restart - usually it will take only a few minutes but can continue for 10-20 minutes in some rare cases. If process hangs - replug power cable and start printer manually. Step 6 Now check current firmware version. If NO - restart the printer and try once more time. Step 7 Extract all files from License.zip archive to local folder on Your PC. Run activation.exe utility and click on Activate Online button and input Your Activation Key. Quote Share this post Link to post Share on other sites
