When I get to the select printer section, I get the following error:
Quote
Printer is not connected or the connected printer is not the target printer
My printer is an Epson XP-15000
Hello! This might be because there are too many printers on devices and printers. That’s what might help you: close the Activator Software, turn off your printer, go to PC and remove all printers that may be in "Devices and Printers", then turn your printer on and it will install again, then open the launcher software again and it might appear normally.
