coby
printer not found
I've downloaded the INKCHIP Adjustment program, paid for the key code and when I go to waste ink Counter it blank  No drop down menu.  When I go to the deep clean the printer is there.  What to I do now?
Coby
Tell me please your order number and printer model. Are you using only USB connection to the printer?
  On 1/6/2024 at 5:19 AM, ivanj said:
hello, I'm having the same problem as the OP. Epson ET-3760 connected to USB. Thanks.
The model ET 3760 is unfortunately not supported by the WIC reset utility.
You can see all supported models on our website:
https://inkchip.net/wic/
  On 1/19/2024 at 3:28 AM, cup1234567 said:
Hi, i'm having the same issue with Epson XP-15000
This model isn’t  supported with WIC adjustment program, only with chipless firmware.
