Please tell me your printer model. Also, send me the screenshot of the error so I can help you. Did you install the Microsoft Visual C++ x64 and x86 2017-2022 packages? If so, please send me the screenshot from the download menu so I can see the exact date and time of packages and WIC reset utility were installed.
Thanks!
22 hours ago, deltachan said:
hello I just bought a key, it says already used how to do it
please Espon XP215. thanks in advance
Did you install the Microsoft C ++ packages before running the utility?
If yes, please send me a screenshot from the download menu, so that I can see the date and time when the packages were installed.
17 hours ago, TEFFO said:
When I want to use the key, I get the following message : "Provided key is already used"
How can you help me, please? I bought the key 2024/01/24. The print is an EPSON SX430W.Order 587948
https://www.casimages.com/i/Erreur 1.html
Thank you
Make sure that Microsoft Visual C++ x64 and x86 packages are version 2017-2022, but not earlier. Make sure the program is reloaded and no longer hangs.
