Bryan0957
Activation not working xp15000
  On 7/27/2023 at 3:59 AM, Bryan0957 said:
The firmware worked but the activation does not show my printer for me to activated.
Make sure you installed firmware successfully.
You should convince that installed the Chipless Firmware in NORMAL mode instead of UPDATE mode.
Please read the instruction from our website carefully:
Also, please watch the video guide from our official YouTube channel:
bonjour, pour ma part il mes impossible de télécharger, le programme il va jusque 99% et puis il me dit qu'il na pas pu installer
que puis-je faire pour réglé ce problème ?
In the video guide it shows that you don't need it to load 100%. When the load gets stuck at 75-85%, that's okay! You will need to pull the cable out at that point and put it back in.
