vic 0 Posted May 27, 2023 RE; Printer Epson XP 3150 there are 2 printers: one for EU and second for Australia.Y our soft is not working for Australian version Cartridges 212. Quote Share this post Link to post Share on other sites
Admin 17 Posted May 27, 2023 9 hours ago, vic said: RE; Printer Epson XP 3150 there are 2 printers: one for EU and second for Australia.Y our soft is not working for Australian version Cartridges 212. Hello! Our solution works with all types of cartridges. Quote Share this post Link to post Share on other sites
vic 0 Posted May 27, 2023 not true,not working with Australian printer. at 99 procent instalation stop and pop up mesage software was not install try again. tried 4 times, same Quote Share this post Link to post Share on other sites
Admin 17 Posted May 30, 2023 On 5/27/2023 at 9:11 PM, vic said: not true,not working with Australian printer. at 99 procent instalation stop and pop up mesage software was not install try again. tried 4 times, same Hello! Please try this updated file with the Chipless Firmware: https://inkchip.net/download/INKCHIP.net_Firmware_99_XP3100_v1.rar 1) Upload the Chipless Firmware which is attached above. 2) Turn on the printer in the NORMAL MODE (using only the power button). Do not put the printer in the UPDATE MODE. The loading process will get stuck at 75-85% - that is OK. 3) With the use of the task manager stop the loading process. Printer will blink for about 5-15 minutes . It should then turn off automatically. 4) Now turn on the printer - Chipless Firmware should be installed! 5) Run the Activation Software to insert your Activation Key. Quote Share this post Link to post Share on other sites
