Successfully updated Epson WF3720.    First fw update, stuck at 97%, second try, 98%, third and fourth tries, 99%, never would finish.  But pulled power, turned on printer and successfully activated.   Thank you!
However I have to ask, how does a person now know when ink cartridges are low?   Going to use refilled cartridges for a while but don't want to run dry and risk print head problems.  What are ways to see or estimate actual ink usage?      Seems it will always show 100%?
In the video guide it shows that you don't need it to load 100%. When the load gets stuck at 75-85%, that's okay! You will need to pull the cable out at that point and put it back in.
