  On 1/16/2023 at 9:23 PM, kraftykreator said:
I have tried for over 2 hours to get the activation link to work with no luck. Please post a new link which will work. Thank you
What is your model of printer?
Epson XP-4105
Currently, I am able to open file and get screen to enter activation code ... in upper box area, I select my printer and choose "Activate online" ... but then I get read failed error...
Edited by kraftykreator
had my activation code in pic ... sorry
Please try this updated file with the Chipless Firmware:
https://inkchip.net/download/INKCHIP.net_Firmware_XP4100_v1.rar
1) Upload the Chipless Firmware which is attached above.
2) Turn on the printer in the NORMAL MODE (using only the power button). Do not put the printer in the UPDATE MODE.
The loading process will get stuck at 75-85% - that is OK.
3) With the use of the task manager stop the loading process.
Printer will blink for about 5-15 minutes . It should then turn off automatically.
4) Now turn on the printer - Chipless Firmware should be installed!
5) Run the Activation Software to insert your Activation Key.
Thanks!
