Ray_C
Unable to "Activate Online"
I have a Epson WF-4734 and I have followed all steps up until I launch the "Activation" tool and when I try to hit Activate Online the platform freezes and crashes. Any urgent help would be appreciated.
I have tried doing the firmware update in both program and normal mode but still when I get to the "Get active code online" stage, it freezes half way through the process. I have also tried the firmware update with both a usb connection and with a network connection. All have failed. What can I do to get this done? Can you help me? I am using  windows 10 pro laptop. No other issues with my laptop. It works flawlessly.
Please try this new activator:
https://inkchip.net/download/activation.rar
Hello - I'm having the same issue with the activator.  I've used both the download from your website and the activation.rar file you refer to above.  I've tried several PCs, have tried several different USB cords and have connected to 3 different networks (home, neighbor's, hotspot).  I've also ran the firmware several times.  The result is always the same - the activation executable freezes and never does anything after that.  My order is 513307 and I am trying to install on an Epson WF-4730.  You can find the image here - Screenshot
On 5/10/2023 at 11:17 PM, jgutierr_post@yahoo.com said:
Hi Admin - that activation.rar did not work either.
You should convince that installed the Chipless Firmware in NORMAL mode instead of UPDATE mode.
